Oentane is a liquid with a vapor pressure of 512 Torr at 25C
To determine the liquid phase composition of a mixture of pentane and hexane that results in equal amounts of each in the gas phase, Raoult's Law is applied. The formula used is P = P_pure_hexane * C_hexane + P_pure_pentane * C_pentane, where P represents the total vapor pressure, P_pure is the vapor pressure of the pure components, and C is the molar composition of each component in the liquid phase. Given that the vapor pressure of pentane is 512 Torr and that of hexane is 151 Torr at 25°C, the goal is to find the molar fractions of pentane and hexane in the liquid phase that would yield equal partial pressures in the gas phase. This involves setting the partial pressures equal to each other and solving for the compositions.
physicsss
Oentane is a liquid with a vapor pressure of 512 Torr at 25C; at the same temperature, the vapor pressure of hexane is only 151 Torr. what composition must the liquid phase have if the gas hase composition is to have equal amounts of pentane and hexane?
Do I use p = i M R T to solve for the M, molar masses? How do I need to get started
Chemistry news on Phys.org
No, you'll need to use the Rault's law
P=P_{pure~hexane}C_{hexane}+P_{pure~oentane}C_{oentane}
where C=molar composition of respective compound
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
