One brick on another (friction, laws of Newton)
The discussion centers on solving a physics problem involving two blocks, A and B, with given masses and friction coefficients. The key focus is determining the force required to initiate movement between the blocks, utilizing static and kinetic friction concepts. Participants emphasize modeling the forces acting on each block through free-body diagrams, highlighting the importance of tension and friction in their calculations. Clarifications are sought regarding which block is being pulled and how to set up equations to find the acceleration and movement threshold. The conversation reflects a collaborative effort to understand the dynamics of the system based on Newton's laws.
Atx
[PLAIN]http://img693.imageshack.us/img693/8219/utennavnu.png
n= normal force
µ*n=friction
F=ma.
T = tension , mA = mass of A, mB mass of B
a) Static friction should be used. Forces on brick A : x: T - µ*mg=0 y dir: n-mg=0
B: x: (mA+MB)g*µ , tension and friction between A and B, y: mg=n , force from A.
b) Kinetic friction is to be used, have tried to find an expression of the acceleration , but so far hasnt come to the right answer.
Could you elaborate on the question please? What exactly are they asking here?
Jared
wow, my bad. :blushing:
A force F is pulling on B in the right horizontal direction. The mass of A is 5.00 kg, the mass of B is 3.00 kg. Static friction between all surfaces is 0.600 , kinetic friction is 0.400. Assuming the blocks are at rest, for what value of F will the blocks be put into movement?
I'd appreciate any hints, I've been stuck on this problem for a while.:frown:
Are you sure it's block B that is getting the force? The picture makes it look like A. Just making sure.
Try modeling the two blocks separately in a free-body diagram, labeling all forces acting on them. Don't forget the forces the blocks exert on each other.
Always trust picture. A is getting the force. I've modeled the forces as a free body diagram.
The forces excerted on B is x: T(tension)-0.3*mg = m*a (where a is the same accelleration as the one on block A). B in y direction is mg-mg=0 which means there is no accelleration in y-direction for either A or B. A is tricky though because its affected by a force of mg in y direction (from the other block) , Mg and a normal force of equal magnitude. In x direction A is affected by T(tension)-0.3*mg but there is also friction between A and B, so how can I set up an equation to find out when the blocks move?
