kingpin29
- 1
A car starts from rest at a stop sign. It accelerates at 4.0 m/s^2 for 6.0 s, coasts for 1.9 s, and then slows down at a rate of 3.0 m/s^2 for the next stop sign.
How far apart are the stop signs?
On helping with questions: Any and all assistance given to homework assignments or textbook style exercises should be given only after the questioner has shown some effort in solving the problem. If no attempt is made then the questioner should be asked to provide one before any assistance is given. Under no circumstances should complete solutions be provided to a questioner, whether or not an attempt has been made.
NOTE: You MUST show that you have attempted to answer your question in order to receive help. You MUST make use of the homework template, which automatically appears when a new topic is created in the homework help forums.
One dimensional velocity refers to the rate of change of an object's position in one specific direction. It is a vector quantity that includes both magnitude (speed) and direction.
One dimensional velocity is calculated by dividing the change in distance (displacement) by the change in time. It is typically represented by the equation v = d/t, where v is velocity, d is distance, and t is time.
While speed and velocity are often used interchangeably, they are not the same. Speed is a scalar quantity that only refers to the magnitude of an object's movement, while velocity is a vector quantity that takes into account both the speed and direction of an object's movement.
Yes, one dimensional velocity can be negative. This indicates that the object is moving in the opposite direction of its initial position. For example, a car traveling east with a velocity of -20 m/s is moving in the west direction.
Acceleration is the rate of change of an object's velocity. If an object has a constant acceleration, its velocity will change by the same amount in each time interval. This can result in an increase, decrease, or change in direction of the one dimensional velocity.
