Optics - right handed circular polarization
The discussion revolves around formulating the electric field expression for a right-handed circularly polarized light wave traveling in the positive z-direction. The initial attempt at the solution led to confusion regarding the direction of the electric field at z=0, t=0, which did not align with the requirement of pointing in the negative x-direction. After some deliberation, a revised expression was proposed, suggesting that the correct formulation should include a negative sign to ensure clockwise rotation. Additionally, a participant pointed out a typographical error in the notation, clarifying that kz should replace kx in the context of the electric field expression. The conversation emphasizes the importance of accurately defining the polarization direction in optics.
DataGG
Write an expression for a light wave circular polarized to the right, traveling in the positive ZZ direction, such that the electric field points in the negative XX direction at z=0, t=0.
Right handed polarization is the same as clockwise, I think..
##E_{0x} = E_{0y}## throughout the whole thing.
$$\vec{E}(z,t)=E_{0x}sin(kz - wt)\vec{i} + E_{0y}sin(kz - wt + \frac{\pi}{2})\vec{j}$$
Well, I'm having a problem.
$$\vec{E}(z,t)=E_{0x}cos(kz - wt)\vec{i} + E_{0y}sin(kz - wt)\vec{j}$$
At ##z=0##, we have
$$\vec{E}(0,t)=E_{0x}cos(wt)\vec{i} - E_{0y}sin(wt)\vec{j}$$
So it indeed moves clockwise (co-sine decreases while the sin increases negatively)
At ##z=0## and ##t=0##:
$$\vec{E}(0,0)=E_{0x}\vec{i}$$ Which does not point in the negative XX direction.
If I place a minus in the co-sine term, then it'll look like this:
$$\vec{E}(0,t)= - E_{0x}cos(wt)\vec{i} - E_{0y}sin(wt)\vec{j}$$
and that means that the co-sine will decrease negatively and the sin increase negatively. That would be a left handed circular polarization, because it would be counter-clockwise. I think?
So, how do I go about doing this?
I think I solved my problem. No idea how I didn't see this sooner. Well, I actually did, but I dismissed it for some reason..
I think the following equation satisfies everything:
$$\vec{E}(z,t)=-E_{0}cos(kz - wt)\vec{i} - E_{0y}sin(kz - wt)\vec{j}$$
Would someone please confirm?
Can anyone confirm it? Is it correct?
While optics is a bit out of my realm, it looks as though what you have will definitely rotate clockwise. If you're not sure you can check the direction of the derivative at a point on the unit circle. If you want the direction it's pointing in check the direction of your function at that point.
Just a quick question, if you have E(z,t), why are you setting kx = 0 at E(0,t) ?
Should that be kz instead?
Likes 1 person
Oh yes, that's definitely a typo. Where it reads ##kx## it should be ##kz##. Thanks for the heads-up, will edit right away!
