Slimsta
- 190
http://img7.imageshack.us/img7/1826/43544187.jpg
whats wrong with my answers? everything looks right to me... :S
HallsofIvy said:The only thing wrong that I see is that you haven't answered the question. You said that the volume will be minimized. You have given x, but you haven't found y and have not said what the dimensions are.
Mark44 said:One of your entry boxes says "This implies that the surface area is given in S only..."
Except for this, everything else it looks fine.
Here's a tip you might consider. Many or most of the problems you have posted have oddball numbers such as a volume of V = 2500.1055 cm^3.
I did all of my calculations using V, and replaced V only in the very last step. This saved my from writing 2500.1055 a bunch of times.
For example, A = x^2 + 4V/x. It's easy to get dA/dx = 2x -4V/x^2. Rewriting this as dA/dx = 2x -4Vx-2, it's easy to get the second derivative and verify that it's positive for all x > 0.
Optimization is the process of finding the best possible solution for a given problem or objective. It involves maximizing or minimizing a certain variable or set of variables, while also considering any constraints that may be present.
"Open box" refers to a type of optimization problem where the variables and constraints are not fully defined or known. This means that the potential solutions are not limited to a specific range, and there may be multiple ways to achieve the optimal solution.
Optimization is used in various fields of science, such as physics, engineering, and biology, to find the most efficient or effective solutions for different problems. It can be used to design experiments, optimize processes, and improve the performance of systems.
Some common optimization techniques include linear programming, gradient descent, genetic algorithms, and simulated annealing. These techniques use mathematical and computational methods to find the optimal solution for a given problem.
Optimization can help save time, resources, and costs by finding the best possible solution for a problem. It also allows for more efficient and effective decision-making, as well as the ability to improve and optimize existing systems and processes.
