Optimize Function: Abs Max & Min Values of -2x^2 + 3x + 6x^(2/3) + 2
  • Thread starter Thread starter pyrosilver
    Optimization
The discussion revolves around finding the absolute maximum and minimum values of the function f(x) = -2x^2 + 3x + 6x^(2/3) + 2. Participants are exploring the necessary conditions for determining these values, including evaluating the function at specific points and analyzing its derivative.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss identifying candidates for absolute extrema by evaluating the function at endpoints and points where the derivative is zero or undefined. There is uncertainty about using a calculator to find the roots of the derivative and how to handle the case where the derivative does not exist.
Some participants have provided guidance on correcting the derivative and suggested using graphing tools to find where the derivative equals zero. There is ongoing exploration of the implications of the derivative being undefined at x = 0 and how that affects the candidates for extrema.
One participant notes a lack of experience with calculators, which may impact their ability to solve the problem effectively. Additionally, there is mention of the function's domain being all real numbers, which is relevant to the discussion of where the function is defined.
pyrosilver
Find the abs max and abs min values of the function
So the candidates are the endpoints, where f'(x) = 0, and where f(x) DNE.
f(-1) = 3
f(3) = 5.481
For the derivative of the function, i got to f(x) = -4x + 3 + (1/(4x^3)). Set it to 0. But I can't find what x is. How do I use my calculator to find this? For the past five years, I haven't been allowed to use a calculator for my math courses, so I don't really know how to do anything with it. This year, I can use one, but I'm not sure how to use it to find x.
Also, f('x) DNE at x = 0. How do I use that information to determine the value to put that as a candidate for the abs max and abs min?
f(-1) = 3
f(3) = 5.481
Your derivative has two errors. It should be f'(x) = -4x + 3 + 4x-1/3. Note that the last term is the same as 4/x1/3, not 1/(4x3), as you have.
Solving for the value that makes f'(x) = 0 involves solving a somewhat messy cubic equation. There are ways to do this analytically, but they're not usually taught.
It could be that you are expected to graph the derivative on your calculator and then observe the value(s) of x at which the y value is zero. I'm assuming you have a graphing calculator. If you don't know how to do this, look at the instruction manual for your calculator.
Ah okay, thanks I'll fix that up.
Actually I don't currently have a graphing calculator, but i just plotted it out on an online one. To make sure the graphing calculator wasn't faulty, is x = .799999? Sometimes the online ones are a bit sketchy.
Thanks for your help!
Anyone know about the DNE case?
The value I'm getting where the derivative is zero is about 1.6.
The domain of f is all real numbers, so there are no numbers at which f does not exist. The derivative isn't defined at x = 0, but you already knew that.
Ah okay, thank you Mark44!
  • · Replies 36 ·
  • · Replies 30 ·
