Order of Operations: Guitar String Frequency
  • Thread starter Thread starter Spookie71
    Operations
The discussion revolves around calculating the frequency of a guitar string when its tension and length change. The initial frequency is 330 Hz under 81 N tension and 60 cm length, and the user seeks to find the frequency under 100 N tension and 25 cm length using the equation f_f = 330 Hz * √(100.0 N / 81.0 N) * (30.0 cm / 25.0 cm). The user struggles with the order of operations, mistakenly calculating the frequency as 440 Hz instead of the correct answer of 417.42 Hz. Clarification is requested regarding the relevant equations and the topic of the problem, indicating a need for further guidance in understanding the concepts involved. The discussion highlights the importance of correctly applying mathematical principles in physics problems.
Spookie71
A guitar string of length 60.0 cm under 81.0 N of tension produces a note of frequency 330.0 Hz. What frequency will the same string produce when under 100.0 N of tension and shortened to 25.0 cm?
Here is the question
f_{f} = 330 Hz * \sqrt{ \frac{100.0 N}{81.0 N}} * \frac{30.0 cm}{25.0 cm}
The answer is 417.42 Hz in the book, I just don't know the order of operations to solve this.
When I try it I take 100.0 N and divide by 81.0 N where I get 1.234567901 and then I push the square root key on my calculator which gives me 1.111111111
I then take 330 * by 1.111111111 * 1.2
Which gives me 440 Hz.
Can you explain where I'm going wrong in my order of operations.
Thanks
Write down the eqn giving frequency in terms of length, tension etc.
Shooting star:
Not sure what you're saying.
I apoligize for my lack of knowlegdge. I'm returning to school to complete my diploma after being out for 15 years. I picked a course that may be a little to advanced for me but I don't want to lose the money I put down for it.
Do you need more information from me as per the equation?
Thanks
S
Actually, I don't know under what topic you're doing this problem. Is it under sound and waves etc or just ratio-proportion or scaling? But the fact remains that unless you give more information about why you're doing what you're doing, with relevant equations, your questions are not possible to reply to. So, for your benefit, I suggest you give more details and write the pertinent equations on the topic. Best wishes.
