Organic Chem: Diels-Alder w/ Anthracene & Maleic Anhydride
The discussion centers on the Diels-Alder reaction involving anthracene and maleic anhydride, specifically addressing the choice of solvent, comparing xylenes to ethanol, and exploring potential side reactions with alcohols.
  • One participant questions why the Diels-Alder reaction is performed in xylenes instead of ethanol.
  • Another participant, identifying as not an expert in organic chemistry, raises a query about the reaction of acetic anhydride with alcohols.
  • A subsequent post suggests that mixing maleic anhydride with alcohol could lead to the formation of ethyl acetate.
  • Another participant seeks clarification on why acetate would be formed in this context.
  • One participant asserts that side reactions with maleic acid and ethanol could result in ester formation.
  • It is noted that xylenes are generally unreactive under mild conditions, only reacting under extreme conditions with certain reagents, while other solvents like toluene and hexanes are mentioned as alternatives.
Participants express differing views on the appropriateness of solvents for the Diels-Alder reaction and the implications of using alcohols with maleic anhydride, indicating that multiple competing views remain without consensus.
There are unresolved assumptions regarding the reactivity of solvents and the specific conditions under which side reactions may occur. The discussion does not clarify the exact mechanisms or outcomes of the proposed reactions.
lenadub
In the Diels-Alder reaction between anthracene and maleic anhydride, why is it carried out in xylenes rather than in ethanol?
Chemistry news on Phys.org
I am not an organiker, so I can be wrong - but what happens when you mix acetic anhdyrides with alcohols?
The maleic anhydride reacts with alcohol to give athyl acetate??
Why acetate?
methods
yep, you've got the right idea. you'd get side reactions with the maleic acid and ethanol to form esters.
xylenes on the other hand, are virtually useless and won't react except under extreme conditions with things like acid chlorides and alkyl chlorides in friedel-crafts reactions. other good solvents would most likely be toluene, hexanes, pentane, petroleum ether, and methylene chloride
  • · Replies 17 ·
  • · Replies 24 ·
26K
14K
10K
9K
