Identifying the Electrophile in But-2-ene and Bromine Reaction
In the reaction of but-2-ene with bromine and concentrated aqueous sodium nitrate, the correct statement is that the mechanism involves an initial electrophilic attack followed by a nucleophilic attack. The electrophile is identified as NO2+, which is formed under specific conditions, despite concerns about its generation from sodium nitrate. The resultant compound exhibits optical activity due to the formation of a chiral center, but the compound's trigonal planar structure allows for attack from both sides, leading to a racemic mixture. The discussion clarifies that 2,3-dibromobutane is not the only product, as other configurations can occur. Ultimately, the consensus is that the mechanism is complex and involves both electrophilic and nucleophilic components.
chewchun
But-2-ene reacts with bromine in the presence of concentrated aqueous sodium nitrate to give the following compound
CH3-C(H)(ONO2)-C(H)(Br)-CH3
Which of the following statement is correct.
a.the electrophile is NO2+
b.Only 2,3-dibromobutane is formed.
c.Resultant solution shows optical activity.
d.Mechanism involves an initial electrophilic attack followed by nucleophilic attack
I know that B is out cause you can have -Br and -OH instead of just 2-Br.
C is also out because the compound can be attacked from both side(Trigonal planar)
A or D is correct.D makes sense to me but isn't NO2+ a electrophile. In this case i would presume NO2+ is somehow formed which attacks OH group...If not what is the case?
See, the halide molecule also polarize and form halide electrophile, in this case, Br+ can form. NaNO3 cannot give NO2+ ion, as it is obtained by "protonation" of nitric acid, which is not a simple task, considering nitric acid itself is very strong acid. That's what I feel.
Name these ions... NO3- and NO2+
Which one is present in your proposed mixture?
Care to elaborate, as chemisttree asked?
UPDATE: I have formed on paper the compound H3C-CH(ONO2)-CHBr-CH3, considering Nitrate group, albeit I am afraid I may have have bent some rules (which looks like the case, forming acid out of aqueous nitrate ions) And I have reached to following answers: C, D.
The answer was given to be D only.
The carbon is directly bonded to oxygen,and the oxygen directly bonded to NO2.So it seems to be O- and NO2+?And i presume the O- to be created from a alcohol group and the H+ is removed...
Answer is not C as the compound is trigonal planar and can be attacked from both sides,hence a racemic mixture..
But i don't understand how C(O)(NO2) is formed as it seems impossible to form NO2+ from this reaction...
Esterification I guess.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
