ORGANIC Chemistry: Nucleophilic Substitution
The discussion revolves around preparing specific molecules through nucleophilic substitution reactions. Participants initially misunderstood the assignment, thinking they needed to identify leaving groups rather than starting materials. Clarification revealed that the task was to determine how to synthesize the given products using appropriate reactants. Examples provided include using (CH3)3C-Br with NaOCH3 to create (CH3)3-O-CH3 and CH3CH2CH2CH2I with NaCN to form CH3CH2CH2CH2CN. The conversation highlights the importance of recognizing electrophiles and nucleophiles in these reactions, as well as the potential for adding carbon chains through nucleophilic substitution.
bluey2014
8) How might you prepare each of the following molecules using a nucleophilic substitution at some step?
a) (CH3)3-O-CH3
b)CH3CH2CH2CH2CN
none
I'm really not sure what's being asked.
I'm going to assume that I need to pick a leaving group and substitute it with some kind of nucleophile...
So...for part a I chose O for the leaving group and part b I chose CN as the leaving group.
However, I have no clue where to go from there...what am I trying to create?
Thanks for any help!
You have it backwards. . . they are giving you the products, and asking how you would make them from (insert your own reactants) using substitution.
I am not sure if I am supposed to help you any further, so I will refrain from more details at this point. . .
The idea is being able to identify parts of a product that would make a good electrophile, or in this case, have already made a good electrophile; as well as knowing what are some GOOD/GREAT nucleophiles, and then use this knowledge to think about how a nucleophile would attack an electrophile to give the desired product.
Others: please feel free to correct me with any terminology or other mistakes I have made, my o-chem is rusty, but hopefully with the more time I spend here it will start to come back to me :P
Ohh, that makes more sense...
Though, I'm still not completely sure how to go about doing this.
We've worked problems like this in class, but the other way. We usually push Br out of the system and then the nucleophile takes its place.
Could I pick Br to replace CN in part b?
In part a, I'm not sure which molecule came in...
EDIT:
I think I figured it out...
(CH3)3C-Br + NaOCH3 ----> (CH3)3C-OCH3 + NaBr
CH3CH2CH2CH2I + NaCN ----> CH3CH2CH2CH2CN + NaI
I have no idea what the first reagent is.
For the second one which contains cyanide, usually we use halogenoalkanes. Halogens usually contains very polarised bonds, since halogens have high electronegativity usually. The polarised carbon would attract a nucleophile which is CN- ions in this case.
You could use for example CH3CH2CH2CH2Cl and acidified KCN solution as reagents. Then CN- ions are likely to attack the C-Cl bond which has positive charge on the carbon atom.
Just giving some ideas
EDIT:
Both of your answers look correct to me, but it would be best if someone else could double check. . .
Another thing of importance to note is that using CN as a nucleophile adds one more carbon to the chain. . . there will be problems later on (in either ochem 1 or 2) where you will have to add carbons, so this is something good to remember.
Yes, CN group could be hydrolysed into carboxylic group and ammonia by either acid or base.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
