Oscillation amplitudeWhat is the amplitude of the oscillation?
The discussion focuses on calculating the amplitude of oscillation and the speed of a cart attached to a spring. The cart has a mass of 1.4 kg and is connected to a spring with a constant of 60 N/m, initially displaced 0.27 m from equilibrium with a velocity of 2.6 m/s. The total energy of the system is derived from kinetic and potential energy equations, resulting in a calculated speed at equilibrium of approximately 3.14 m/s. The amplitude of the oscillation is determined to be about 0.324 m. The calculations appear to be correct based on the provided equations and energy conservation principles.
kolua
A 1.4-kg cart is attached to a horizontal spring for which the spring constant is 60 N/m . The system is set in motion when the cart is 0.27m from its equilibrium position, and the initial velocity is 2.6 m/s directed away from the equilibrium position.
A. What is the amplitude of the oscillation?
B. What is the speed of the cart at its equilibrium position?
E=K+U
U=½kΔx2 =½⋅60⋅0.272=2.187J
K=½mv2=½⋅1.4⋅2.62=4.732J
E=K+U=½mvf2
Is this the right way to proceed?
Your first equations are correct and the K+U for E (the total energy at that point) is correct, but now you need to balance T against the U of the spring at the maximum amplitude of the oscillation.
E=K+U
E=K+U=½mvf2
Yes, that will give you the answer to one part. What about the other?
the Velocity at the equilibrium would be, √(2(2.187+4.732)/1.4)=Ve=3.14m/s
then E=½mVe2=½kΔX2, this X here would be the amplitude. X=0.324
Haven't checked the numbers in detail, but that looks right.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
