Oscillation Problem. Advice need please
  • Thread starter Thread starter Seiya
    Oscillation
2 replies · 2K views
Seiya
Oscillation Problem. Advice need please :)
An object of unknown mass is hung on the end of an unstretched spring and is released from rest. If the object falls 4.27 cm before first coming to rest, find the period of the motion.
All i can figure out is that the maximum amplitude is a given and ocurrs when cos of (wt) is 1
from this i could know that v = -Aw if i had a value for time... right now I am really confused, any advice would be really helpful, thank you
The equation for period of oscillation is [tex]T = 2\pi \sqrt{\frac{m}{k}}[/tex].
The information given let's you find a relationship between the mass and the spring constant. By the principle of conservation of energy:
PE1 + KE1 = PE2 + KE2
KE1 = 0 as the mass was hung at rest. PE1 = PEspring1 + PEgrav1: you can consider the h to be zero here, then both are zero as well.
Would you like to try the energy analysis at point 2, when it is at the bottom and the string is maximally stretched at 4.27 cm?
Thanks i really got to start doing this problems earlier in the morning so i can think broader ;p
energy at the bottom:
-mgx+1/2w^2mx^2
0 = PEbottom
T= 2piw
done
thank you
