Oscillations Car carrying four people find how much body rises
A 1175 kg car with four passengers weighing 80 kg each bounces on a rough dirt road with corrugations 4.0 m apart at a speed of 17 km/h. The natural frequency of the car's suspension was calculated to be 445.059 rad/s, and the spring constant was found to be 3.75e8 N/m. The attempt to calculate the rise in the car body due to the decrease in weight after the passengers exit resulted in an incorrect value of 1.8e-5 m. The error was identified as a unit conversion mistake when converting speed from km/h to m/s. Proper unit conversion is crucial for accurate calculations in physics problems.
GingerBread27
A 1175 kg car carrying four 80 kg people travels over a rough "washboard" dirt road with corrugations 4.0 m apart which causes the car to bounce on its spring suspension. The car bounces with maximum amplitude when its speed is 17 km/h. The car now stops, and the four people get out. By how much does the car body rise on its suspension owing to this decrease in weight?
I first tried figuring the natural frequency of the car:
\omega_o=(2\pi\upsilon)/(\Delta(x))=(2\pi(17km/h)(1hr/60s)/(.004km) This gives 445.059 rad/s.
I then tried to figure out k:
\kappa=(m1+m2)\omega_o^2=((1175 kg+(4*180kg))(445.059rad/s)^2 This gives 3.75e8.
Finally, I tried finding \Delta(x)=\Delta(F)/\kappa=(m_2*g)/(\kappa)=((180 kg*4)(9.8m/s^2))/(3.75*10^8)This gives 1.8e-5 m, or .00188 cm, this is wrong, where did I go wrong? Help!
PS This is the first time I use Latex so if it looks odd I'm sorry!
Help...Anyone lol...
your conversion for the first part seems to be off... recheck it... and make sure you convert to meter seconds... but you're on the right track
i just solved my homework problem with your equations and it worked. the only problem with your method is your unit conversions: to go from km/h to m/s you multiply by 1000/(60^2)
