Parallel Circuits - Joining 2 branches together
  • Thread starter Thread starter wolfsloth
    Circuits Parallel
The discussion revolves around a problem involving parallel circuits, specifically focusing on the behavior of current and potential differences across various resistors when two branches are joined together. Participants are analyzing the implications of circuit simplifications and the direction of current flow.
  • Participants explore the direction of conventional current and its impact on potential differences. There are attempts to simplify the circuit by combining resistors in parallel and questioning the assumptions about the connections between points B and E.
The discussion is active, with participants providing guidance on circuit simplification and questioning the validity of the original problem setup. Some participants express confidence in their calculations, while others suggest that the problem statement may contain errors.
There is mention of potential differences across points B and E and the implications of joining these points with a wire. Participants are also considering the accuracy of the provided answers in relation to their calculations.
wolfsloth
I'm stuck at part (b)
V = IR (ohm's law)
V1 = (R1 / (R1 + R2) ) * V (potential divider)
I started off by thinking which direction conventional current would flow.
I concluded that the potential at B will be higher than the potential at E, so the current will flow from B to E. Thus, the current will not flow through the 3 Ω resistor.
This was the new circuit diagram I drew (where I thought the current would flow now):
However, the answers I got for PD across AB and DE were wrong.
So I think my concept of the direction of current flow is wrong.
Hello wolfsloth, :welcome:
I see two pictures of the new situation: one has 4.0 ##\Omega## and the other 1 ##\Omega## on the right. You continue with the 1 ##\Omega##, as if the 3 ##\Omega## is absent.
The points B and E are joined by a wire. A wire (in most exercises) has no resistance, so the potential on one end is the same as on the other end. I e. both the 3 and the 1 'see' the same potential difference: they are effectively in parallel, just like the 2 and the 4 on the left.
I would forget about trying to work out where currents are going for the moment. Instead try and simplify the circuit first. On the left you have a 2R and a 4R in parallel. On the right you have a 3R and 1R in parallel. Replace the 2R//4R with one equivalent resistor. Replace the 3R//1R with another equivalent resistor. Redraw the new circuit.
Hi everyone, thank you for the reply!
Unfortunately, seeing the two resistors on the left as connected in parallel and the two resistors on the right as connected in parallel gives me the wrong answer :(
Here are my workings:
Correct answer should be 0.8V for PD across AB and 1.6V for PD across DE
Also, if you refer to part (ii), there is a potential difference across points B and E :O
Your working is correct. There must be something wrong with the book answer -- it can not be that the two answers differ.
+1
I agree. Your working is 100% correct. There is definitely something wrong with the question and/or the answer.
With BE joined the voltage AB and DE should be the same. That's because nodes A and D are connected together and B and E are connected together.
The 0.8 V for AB and 1.6 V for DE are the values before B and E are joined by a wire.
So I suspect the line ' (b) The points B and E are now joined by a wire ' is misplaced and should have been on the next page
