Calculating Equivalent Series Resistance and Inductance for Parallel Branches
To calculate the equivalent series resistance (Req) and inductance (Xeq) for two parallel branches, the correct method involves combining the complex impedances of each branch. The formula Zeq = (R1+jX1)*(R2+jX2)/((R1+jX1)+(R2+jX2) should be used to find the equivalent impedance, which can then be converted to polar form to extract the equivalent resistance and reactance. The simpler method of calculating Req and Xeq separately does not yield accurate results, as it overlooks the interaction between the resistances and reactances. It is crucial to ensure that calculations are done in the correct format, especially when dealing with per unit values. Using the combined approach will provide the correct equivalent values for the parallel branches.
Physicist3
Hi,
If I have two brances, branch 1 and branch 2 which are in parallel and each branch has a resistance and inductance, to calculate the equivalent series resistance and inductance, can I calculate the resistance and inductance separately e.g.
Req = R1*R2/R1+R2 (and same for X),
or do I have to do it combined E.g.
Zeq = (R1+jX1)*(R2+jX2)/(R1+jX1)+(R2+jX2), and then convert to polar etc and back to rectangular to find the equivalent R and jX values? The two methods give me different answers?
Sorry, forgot to add, the values of R and X are in PER UNIT
And the second one is correct. That should answer if the first one works.
Note that there are brackets missing.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
