How Do You Calculate Electric Field and Potential in a Parallel Plate Capacitor?
To calculate the electric field and potential in a parallel plate capacitor, the charge density is determined using the formula charge density = q / a. The electric field (E) is calculated as E = charge density / permittivity, leading to an initial value of 2*10^-3. The potential difference (PD) is found by multiplying the electric field by the distance between the plates, resulting in PD = 1*10^-5. The energy stored in the capacitor is calculated using the formula u = 0.5 * V * q, yielding an energy of 2.5*10^-13 J. Corrections were suggested regarding the orders of magnitude and the use of permittivity, emphasizing the need for accurate calculations.
ledwardz
A parallel plate capacitor has a charge of 50pC
area = 10mm^2
dielectric material permittivity = 2.5
distance between plates = 0.5 mm
find the electric field
the potential difference between the 2 plates
the energy stored in the capacitor
electric field = Charge density / permittivity
therefore E = 5*10^-3 / 2.5 = 2* 10 ^-3
PD= Ed = 2*10^-3 * 0.005 = 1*10^-5
energy u = 0.5V*q = 0.5 * 1*10^-5* 50*10^-9 = 2.5*10^-13 J
can anyone tell me if this is correct? thanks again for any help. Cheers, Lee:shy:
You seem to have lost track of the orders of magnitude in the charge density. Check the calculation.
The permittivity κ is a multiplier for the vacuum permittivity, εo.
ahh pooo. so ε = εor but i have the right idea for the rest of the equation?
thanks for reply also.
Sure. Straighten out the powers of ten and the permittivity and you're golden.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
