Parametric plot / I just need to check my work (quick)
The discussion focuses on the parametric equations for the trajectory of a baseball, defined by x(t) and y(t) based on initial speed, angle, and height. The user seeks feedback on their plots for different angles of elevation, expecting parabolic shapes for the first two angles and a vertical line for the third. There was confusion regarding the units of measurement, but it was clarified that the initial speed is indeed in feet per second. The user ultimately plans to review their Mathematica command to resolve the discrepancies in the plotted graphs. The conversation highlights the importance of consistent units and correct plotting commands in parametric equations.
DivGradCurl
x(t)= \left( u\cos A \right) t
and
y(t)= \left( u\sin A \right) t - \frac{gt^2}{2} + h
represent the horizontal and vertical coordinates of a batted or thrown baseball. A is the initial angle of elevation and u is the initial speed of the ball. I need to plot x(t) and y(t) parametrically. I'm given the following
u = 125 \mbox{ ft/s}
g = 32 \mbox{ ft/s}^2
h = 3 \mbox{ ft}
A may take several different values. Here follows the random choices I made and the corresponding graphs:
A=\frac{\pi}{3}
http://img25.imagevenue.com/img.php?loc=loc93ℑ=663_parametricplot_1.jpg
A=\frac{4\pi}{9}
http://img6.imagevenue.com/img.php?loc=loc123ℑ=26c_parametricplot_2.jpg
A=\frac{\pi}{2}
Could you please take a quick look at those graphs? In my opinion, there seems to be something wrong.
Thank you
I can't see the images. You should be getting parabolas for the first two, and a vertical line for the third (since the ball goes straight up and down.)
Oh, I'm sorry about that. I actually tested the links, but a minute later they just wouldn't work. If you still want to take a quick look, I placed them at:
photos.yahoo.com/thiago_j
They're the only ones there. What you said about the shapes sound right to me, but that's not what I have. They are pretty much the same. I used the command (mathematica 5):
ParametricPlot[{x(t), y(t)}, {t, t_min, t_max}]
Anyway, that's definitely stange.
The discrepancy is probably because you cite g in feet per second squared and your initial velocity in meters per second. Your equation forms are correct.
Oh, no! That's a typo. u = 125 ft/s. The units are incorrect in my 1st post.
I don't have a clue what else I could do.
I managed to get in my calculator what NateTG predicted: "getting parabolas for the first two, and a vertical line for the third". All I got to do now is go over my mathematica command so that I can fix it.
Thank you guys
