Finding Constants for Partial Fraction Integration
  • Thread starter Thread starter gordda
    Fraction Partial
To solve the integral ∫(5x^2-3x+1)/((x^2+1)(x-2)) dx, the first step is to express the integrand using partial fractions. The correct form is (Ax+B)/(x^2+1) + C/(x-2), where A, B, and C are constants that need to be determined. The user initially struggled with both partial fraction decomposition and substitution techniques. To proceed, one must equate coefficients after multiplying through by the denominator to find the values of A, B, and C. This method will facilitate the integration process.
gordda
hello, i have the Intergal ∫(5x^2-3x+1)/((x^2+1)(x-2)) dx
i do not know what to do first, i firstly tried to change to partial fraction but that didn't work to, then i tried substitution technique and again i didn't have anything to substitue that got me any further, i don't know what else to try, somebody please help.
thanx:)
Show us your partial fractions work.
Determine constants A,B,C so that:
\frac{5x^{2}-3x+1}{(x^{2}+1)(x-2)}=\frac{Ax+B}{x^{2}+1}+\frac{C}{x-2}
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
