Partial Fractions turn out wrong
authgeek
Here's (what I think is) a step in partial fractions that I don't understand:
http://apthtml.com/images/partialfrac.png
I'm taking the regular partial fractions steps and I keep ending up with 1 / (1 - x) rather than 1 / (x - 1). What am I doing wrong?
Are the signs the same as well? Remember, -1/(x-1) = 1/(1-x).
You don't show your steps, so I don't know what you are doing wrong. But try this. Let x be 0.5.
\begin{align*}<br /> x &amp;= 0.5 \\<br /> \frac{1}{x(1-x)} &amp;= \frac{1}{0.5 \times (1 - 0.5)} \\<br /> &amp; = \frac{1}{0.5 \times 0.5} \\<br /> &amp;= \frac{1}{0.25} \\<br /> &amp; = 4 \\<br /> \frac{1}{x} - \frac{1}{x - 1} &amp;= \frac{1}{0.5} - \frac{1}{0.5 - 1} \\<br /> &amp; = 2 - -2 \\<br /> &amp; = 4 \\<br /> \frac{1}{x} - \frac{1}{1 - x} &amp;= \frac{1}{0.5} - \frac{1}{1 - 0.5} \\<br /> &amp; = 2 - 2 \\<br /> &amp; =0<br /> \end{align*}​
So you can see the second form has to be wrong.
If you can't see which step of your argument is false, just substitute 0.5 for x at all points, and see at which step you get the wrong answer. Stare at that step until you are enlightened.
Cheers -- sylas
slider: that's definitely the case here, subtle switching of signs and a reversal rule I wasn't aware of. I suppose knowing these rules just comes with doing a lot of math.
silas: I appreciate the detailed answer, and particularly your advice to "Stare at that step until you are enlightened." I feel like I do that quite often... and it works!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
