Particle in an Electric and Magnetic Field
An electron with an initial velocity and constant acceleration in the positive x direction is analyzed in the presence of uniform electric and magnetic fields. The magnetic force along the x-axis is calculated to be 2.4412 x 10^(-18) N, but the cross product of velocity and magnetic field yields zero, leading to the conclusion that the electric field must be in the negative x direction. The correct electric field component in the x direction is determined to be approximately 15.238 V/M. The discussion emphasizes that the acceleration of the electron confirms the direction of the electric field. Understanding the relationship between electric and magnetic forces is crucial for solving the problem.
kinof
An electron has an initial velocity with an x component of zero, a y component of 12.4 km/s, a z component 13.5 km/s, and a constant acceleration of 2.68 x 1012 m/s2 in the positive x direction in a region in which uniform electric and magnetic fields are present. If the magnetic field has a magnitude of 463 µT and is in the positive x direction, find the (a)x, (b)y, and (c)z components of the electric field.
Lorentz Force:
$$\vec{F}_B=q[\vec{E}+(\vec{v} \times \vec{B})] $$
$$\vec{F}=m\vec{a} $$
I have managed to get all of them but (a), which seems like it should be the easiest.
I've found that the magnetic force along the x-axis is 2.4412*10^(-18) N. The cross product of the velocity and the magnetic field along the x-axis is zero. So we have
$$\vec{F}_B=q\vec{E}_x $$
so the answer should be roughly 15.238 V/M in the x-direction. What am I doing wrong?
Consider E should be in the -x direction.
Write F = ma for x, y and z.
Solve for Ex, Ey and Ez.
(Can only be done if ay = az = 0 assumed thruout which I guess it is).
BTW I got the same number for Ex that you did.
EDIT: whoops, better take barryj's hint!
If the electron is accelerating in the +x direction, then the E field is from + to - and has to point in the -x direction.
Motion seconded and carried.
