Particle in Simple Harmonic Motion
A 1kg object attached to a horizontal spring is released from an initial stretch of 0.100m, and the time until its speed is zero again is 0.500s. The spring constant k was calculated as 98 N/m, leading to an angular frequency ω of 9.90 rad/s. The maximum speed was initially calculated as 0.990 m/s, but the correct maximum speed is 0.628 m/s due to the oscillation frequency being 1 Hz. The time value of 0.500s is crucial for determining the frequency of oscillation, which ultimately affects the maximum speed calculation. The problem was resolved by recognizing the importance of frequency in the context of simple harmonic motion.
Willjeezy
Not exactly sure why a time value of 0.500s is given, but I am positive it is why my answer isn't correct:
Q. a 1kg object is attached to a horizontal spring. The spring is initially stretched by 0.100m and the object is released from rest there. It proceeds to move without friction. The next time the speed of the object is zero is 0.500s later. What is the maximum speed of the object?
Vmax = Aω
ω=√(k/m)
Fs=-kx
Given:
t = 0.5s
Amplitude: 0.100m
m: 1kg
I can find k:
Fs=-kx
mg = -kx
(1kg * -9.8) = -k (0.100m)
k = 98 N/m
Find ω
ω=√(k/m)
= √(98/1)
= 9.90
Vmax = Aω
=(0.1)(9.90)
=0.990 m/s.
However, the answer is 0.628m/s. I don't understand the purpose of "the next time the velocity is zero is 0.5s later" I interpret that as:
"it to 0.5seconds to reach negative amplitude", which to my understanding isn't needed?
wait I see my problem, it is moving horizontally not vertically so mg = -kx doesn't apply here.
v = m / s
= 0.2m / 0.5s
= 0.4 m/s
don't know how to go about finding acceleration from here.
Think. If the next time the speed is zero is in 0.5 second, then what is the frequency of the oscillation?
to anyone wondering in the future...
the mass was actually the unneeded info:
ω=2∏f
frequency is = # cycles / s
= 1 hz in this situation
then use Vmax
SOLVED. Thanks.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
