Particle physics exam preparation
In summary: It was invented to explain the properties of the neutron.What does the neutron have to do with it?Multiplets are characterized as having same spin angular momentum and orbital angular momentum.What does that mean?The strength of nucleons interacting is the same regardless of which nucleons are interacting.Neglecting the electromagnetic force.In summary, the homework statement is about baryons and quarks. Neutral kaons are composed of a strange antiquark and an up antiquark and this violates the symmetry. Some evidence suggests that this might be why matter dominates antimatter in the universe. There are two types of neutral kaons and they can be identified by studying the decay products. CP violation is when
Schwarzschild90
113
See the PDF.
I would like some pointers as to what would be most relevant to talk about
Amplitude, cross sections and decay rates.
1) Particle classification: From the Eightfold way to the quark model[/B]
  • Particles are classified approximately by their mass.
  • There are two families of particles: Hadrons and Leptons. The hadrons being the heaviest and the leptons the lightest.
  • Hadrons are further subdivided into baryons and mesons. Baryons being the heavier of the two. A distinguishing characteristic being that baryons are composed of three quarks and mesons of a quark and an antiquark.
  • [Baryons] Eight baryons exist in all, and comprise six of the vertices of the baryon octet; the remaining two particles occupying the middle of the diagram. The Eightfold Way arranges mesons and baryons into the vertices of geometric shapes according to charge and strangeness.
  • Protons are the most stable and in time all other baryons decay into the proton.
  • [Antibaryons] Eight antibaryons exist in all. To get the an antibaryon, reverse the sign of all quantum numbers.
  • [Mesons] contain a quark and an antiquark pair. The diagram form the pseudoscalar meson octet.
  • [Leptons], as quarks, are categorized as elementary particles; their substructure being unknown.
  • Six leptons exist in all. {electron, muon, tau} and their neutrinos. Leptons have an associated lepton number, [electron number], [muon number] and [tau number]. Leptons are subject only to the weak force.
  • [The Baryon Octet] is a geometric model of the eight known baryons. The diagonal lines denote strangeness (-1, 0, 1), while the horizontal lines denote charge (-1, 0, 1). The intersection of these three lines form the vertices of a six sided shape and two particles constitute the center.
2) Neutral Kaons and the violation of CP
  • What are neutral Kaons?
  • Neutral kaons are composed of a strange antiquark and an up antiquark.
  • If a complex phase term exists, then it will give rise to direct CP violation, which could explain why matter dominates antimatter in the universe. Proven for the CKM matrix and expected for the PMNS matrix.
  • How can one distinguish the two types of neutral Kaons?
  • The type of neutral kaon in question, can be found out, by studying the decay products.
  • The neutral kaon decaying into two pions has positive CP violation, the one decaying into three pions, has negative CP violation.
  • What is CP violation?
  • Consider a beam of kaons. After a short while, it so happens that all the $K_s^0$kaons have disappeared, leaving just the $K_L^0$kaons. Thus, the $K_L^0$kaons do something they're not supposed to do.
  • What is CP?
3) What is isospin? Isospin symmetry and its implications for nucleon-nucleon scattering.
  • Isospin is a quantum number related to the strong interaction.
  • Formally, it is not actually a spin, but it is mathematically related to spin and orbital angular momentum. Thus it can be coupled in the same manner.
  • Properties of isospin
  • It can be coupled as 1 or 0.
  • It is a type of symmetry seen most commonly in baryons and fermions.
  • Was invented to explain the properties of the neutron.
  • Neutrons and protons are nearly identical in mass. It was proposed that the difference in mass could be attributed to the energy that the proton stores in the positive electric field.
  • The strength of nucleons interacting is the same regardless of which nucleons are interacting. Neglecting the electromagnetic force.
  • Multiplets are characterized as having same spin angular momentum and orbital angular momentum.
  • Questions.pdf
Tau is heavier than a proton, for example.
And what about the elementary bosons?
Compare J/Psi and a proton...
Way more than eight.
What about the neutron in deuterium?
There is really good evidence that they do not have a substructure.
The topic is about baryons and quarks. Many of your points are about leptons, and you don't even list how many quarks we know.
That violates what you said above.
Phase term of what?
I don't think you mean "CP violation" here.
What are they doing?
I think the subtopic selection here is better.
What would be uncommon?
· A hadron is a composite particle made of quarks held together by the strong force.
o Now, baryons composed of three quarks and mesons are composed of a quark and an antiquark.​
· Now, what are quarks?
o Quarks are denoted as being elementary particles in the standard model, as a consequence of their substructure being unknown. Thus it assumed that they are not composed of other particles.​
o They come in six flavours: Up, down, bottom, charm and strange. Conversely, there are also six antiparticles.​
o Now, ordinary matter is composed of baryonic matter: up and down quarks and the electron, which is a lepton. The rest are of the elementary particles are considered by many to be exotic particles.​
· The Eightfold Way arranges mesons and baryons into the vertices of geometric shapes according to charge and strangeness.
o The Baryon Octet is a geometric model of the eight lightest baryons. The diagonal lines denote strangeness (0, 1, -2), while the horizontal lines denote charge (-1, 0, 1).​
§ Six baryons make up the six vertices of the baryon octet, with two particles occupying the middle of the diagram.​
§ The intersection of these three lines form the vertices of a six sided shape and two particles constitute the center.​
o The eight lighest mesons fill a similar hexagonal pattern, forming the pseudoscalar meson octet.​
§ Now, once again the diagonal lines denote charge (-1, 0, 1), while the horizontal lines denote strangeness (1, 0, -1).​
§ Now, Gell-Mann could just as well have assigned the proton and neutron a strangeness of 1, but he thought it seemed more natural to let the most familiar particles proton, neutron and pion, a strangeness of 0, in their respective geometrical models.​
o Now, not only hexagons are allowed in the Eightfold Way. There was also a triangular array, incorporating the 10 heavier baryons in a baryon decuplet.​
§ A decuplet is a word that means 10 of a kind.​
§ Now, once again the diagonal lines denote charge starting from the bottom (-1, 0, 1, 2), while the horizontal lines denote strangeness starting from the top (0, -1, -2, -3).​
§ The baryon decuplet was experimentally confirmed in 1964, when the particle comprising the lowest vertex of the baryon decuplet and having the exact properties that Gell-Mann had predicted years before, was discovered.​
· Why do hadrons fit into these bizarre paterns? The explanation was offered by the Pauli exclusion principle and quantum mechanics.
o Recall hadrons are composed of quarks. The down, up and strange quarks form a triangular “Eightfold-Way” pattern. Up has Q=2/3 and S=0, strange has Q=-1/3 and S=-1 and down quark has Q=-1/3 and S=0. The antiquarks form a reverse triangle, with the antistrange quark sitting at the top vertex.​
o Now, the baryon decuplet and the meson octet can be constructed by elementary arithmetic. We list the combinations of three quarks or quark-antiquark combinations to make the baryon table or meson table.​
o Now, the baryon octet can be counterintuitively gotten at, by handling spin.​
· Spin is an essential parameter in classifying particles. Particles of half integer spin are classified as fermions and particles of integer spin are classified as bosons.
o Spin classification determines the energy distribution in a collection of particles.​
o Integer spin particles obey Bose-Einstein​
o Half integer spin particles obey Fermi-Dirac statistics.​
1. What topics should I focus on for my particle physics exam?
For your particle physics exam, it is important to have a strong understanding of the fundamental concepts, such as quantum mechanics, special relativity, and electromagnetism. You should also review topics related to particle interactions, symmetries, and the Standard Model of particle physics.
2. How can I best prepare for my particle physics exam?
To prepare for your particle physics exam, it is recommended to review lecture notes, textbooks, and practice problems. It can also be helpful to form study groups with classmates and discuss challenging topics together. Additionally, familiarizing yourself with past exam questions can give you an idea of the level of difficulty and types of questions that may be asked.
3. Are there any online resources I can use to study for my particle physics exam?
Yes, there are many online resources available for studying particle physics. Some popular options include online lecture videos, practice problems, and interactive simulations. You can also find study guides and review materials on educational websites and forums.
4. How should I approach answering math-based questions on my particle physics exam?
When answering math-based questions on your particle physics exam, it is important to show all your work and clearly explain your thought process. Make sure to use the correct formulas and show all necessary calculations. It can also be helpful to double-check your answers and make sure they make sense in the context of the problem.
5. What can I do if I am struggling to understand a certain concept in particle physics?
If you are struggling to understand a concept in particle physics, it is important to seek help from your professor, TA, or classmates. You can also find online resources, such as tutorial videos or study guides, that may offer a different perspective on the topic. Don't be afraid to ask questions and seek clarification to ensure a strong understanding of the material.
