Understanding the Effects of Electric and Magnetic Fields on Charged Particles
The discussion focuses on the effects of electric and magnetic fields on charged particles. It clarifies that if a charged particle moves in a straight line, the magnetic field in that region can be considered zero, as there is no force acting on it. The motion of charged particles distinguishes electric fields, which cause straight-line acceleration, from magnetic fields, which result in curved or spiral paths. When a cosmic ray proton approaches Earth, it will not be deflected, while an electron may deflect to the right or left due to the Earth's magnetic field. Overall, understanding the differences in particle behavior in these fields is crucial for solving related physics problems.
Dhooy7
1. If a charged particle moves in a straight line through some region of space, can you say that the
magnetic field in that region is zero? Explain.
2. How can the motion of a charged particle be used to distinguish between an electric field and a
magnetic field?
3. If a cosmic ray proton approaches the Earth from outer space along a line toward the center of the
Earth that lies in the plane of the equator, in what direction will it be deflected by the Earth’s magnetic
field? What about an electron? A neutron?
1. If a charged particle moves in a straight line though space, you can say that the magnetic field in the region is zero. This is because the cosine of 0 is 0, so the magnetic field is zero. The force is in the same direction as the velocity which creates an angle of 0 degrees. Thus, there is no force.
2. I don't understand this at all. My professor was saying something about affecting the particles e field in a straight line versus curving for the e- field.
3. I don't know where to start on this one to be honest.
[/B]
3. For number 3, the professor or your book should have told you something about the Earth's core, and knowing that it has a metallic core that creates an electric field of some sort the magnetic poles are created right? So use this information to guide your thinking. Think of the Earth as a great big magnet of some sort, and think of how electrons react in a magnetic field.
2. For number 2, think about what are the main differences between the fields, and how they react to electrons and protons. Refer back to your book for this.
2. A charged particle can be used to distinguish between an electric field and a magnetic field because a charged particle that is moving (or not moving right away) in an electric field will be accelerated in the direction of the electric field (straight line). However, a charged particle that is moving in a magnetic field will move in a spiral and curve.
Is number 1 right?
3. It won't be deflected. An electron will go to the right or left?
Is number 1 right?
I didn't really read over number 1, but cos(0)=1 so you are wrong with the knowledge you presented, show the equation you used next time.
Also for Number 2, assuming that you are in a conceptual physics class (Paul G. Hewett book maybe?) You should think about how a charged particle reacts in a magnetic field and how it reacts in an electric field and I am confused on what you mean by "spiral", do you mean that it will tend to want to go to one of the poles, if so, then you may be on the right track.
