Particle Velocity: Speed for 1m Wavelength?
In summary: It is not a multi-eV electron.In summary, The conversation discusses the velocity and wavelength of an electron and the possibility of matter waves with macroscopic dimensions. The calculations show that an electron with a wavelength of 1 meter would have a velocity of 7.28 x 10^-4 m/s and an energy of 3 x 10^-18 eV. This is much lower than the energy typically seen in electrons. Additionally, for a bound particle, there would be a minimum energy corresponding to the lowest energy level.
ognik
643
To what velocity would an electron (neutron) have to be slowed down, if its wavelength
is to be I meter? Are matter waves of macroscopic dimensions a real possibility?
2. Homework Equations
I have assumed this could apply to pretty much any free particle of mass m, and is an introductory question only in nature.
3. The Attempt at a Solution
I have added the units below
I took ##p=\frac{h}{\lambda}##, with ##\lambda=1m##, so that in general for particles, ##v = \frac{h}{m} = \frac{6.626 \times 10^{-34} J.s} {1m \times 9.1 \times 10^{-31}kg} = 7.28 \times 10^{-4} m.s^{-2}##?
For the 2nd part of the question, it seems to me that the velocity is unrealistically slow for a free particle, and would be more so for those with higher mass. I find the 2nd part of the question a little ambiguous, but assuming they are referring to wavelengths of the order of 1m, it would seem from this that waves of macroscopic dimensions are unlikely?
Your calculations are missing units.
Well, depends on "macroscopically". Double-slit experiments with electrons, atoms and even small molecules have been performed. Bose-Einstein condensates allow to reach even lower energies, with wavelengths of millimeters.
Likes ognik
mfb said:
Your calculations are missing units.Well, depends on "macroscopically". Double-slit experiments with electrons, atoms and even small molecules have been performed. Bose-Einstein condensates allow to reach even lower energies, with wavelengths of millimeters.
I had read about that, but supposed that for this question they wanted a reply based on the velocity I found; I really can't read much into that velocity myself. I wonderede about quantisation of energy, so used ##\Delta E = h \nu = \frac{hv}{\lambda} = 4.8 \times 10^{-37}J = 3 \times10^{-18} eV ## - this looks too low to me, wouldn't there be a minimum energy ?
There is no minimal energy - unless you constrain the spread of the particle (e.g. to 1 meter).
Be careful with the energy calculation here: for massive particles, the product of frequency and wavelength is not the speed of the particle. You need a different way to calculate it.
Likes ognik
Thanks mfb, point to remember.
Firstly, is my velocity calculation OK?
In the absence of any known potential, we can use the KE, where ##T=\frac{1}{2}mv^2 = 5.03 \times 10^{-38} J = 3.15 \times 10^{-19} eV## ? Still seems very low?
On a side point - for a bound particle (eg electron in an atom) - then there would be a minimum energy corresponding to the lowest energy level?
Should be m/s, but apart from that it looks fine.
Well, it is very low.
Sure. On the other hand, the zero is a bit arbitrary for the potential. But you have a minimal kinetic energy.
Likes ognik
Oops on the m/s.
I was expecting to find the energy of the order of 1eV, if an electron got knocked out of a ground state orbital for example, wouldn't it have at least that amount of energy? I'm wondering if the value I got is reasonable (given that we are using more classical physics)?
Well, typically electrons have way shorter wavelengths - that's what the calculation is showing.
Likes ognik
1. What is particle velocity?
Particle velocity is the speed at which particles move in a given direction. In the context of a 1m wavelength, it refers to the speed at which particles travel as a wave with a wavelength of 1 meter.
2. How is particle velocity measured?
Particle velocity can be measured using various instruments such as accelerometers, seismometers, or laser Doppler vibrometers. These instruments measure the displacement or motion of particles and can calculate the velocity based on the wavelength.
3. What factors affect particle velocity?
Particle velocity can be affected by various factors such as the properties of the medium through which the particles are traveling, the frequency of the wave, and the amplitude of the wave. Additionally, the temperature and pressure of the medium can also impact particle velocity.
4. How is particle velocity related to frequency and wavelength?
Particle velocity is directly proportional to the frequency of the wave. This means that as the frequency increases, so does the particle velocity. However, particle velocity is inversely proportional to the wavelength. This means that as the wavelength increases, particle velocity decreases.
5. Why is particle velocity important in studying waves?
Particle velocity is an important parameter in understanding and analyzing different types of waves, such as sound waves, seismic waves, and electromagnetic waves. It helps scientists and researchers to measure and characterize the behavior of these waves and their effects on the surrounding environment. Additionally, particle velocity is essential in fields such as acoustics, geophysics, and engineering.
