Equivalence Relations for Partition on R^3?
  • Thread starter chocolatelover
  • Tags
    Partition
In summary, the equivalence relation associated with a horizontal partition of R^3 is z= z0. For a partition in which the z coordinate is not the same as the x and y coordinates, the equivalence relation is (x,y,z)~(a,b,c).
chocolatelover
239
Suppose that we partition R^3 into horizontal planes. What equivalence relation is associated with this partition? Suppose that we partition R^3 into concentric spheres, centered at (0,0,0). What equivalence relation is associated with this partition?
Since it is on R^3, I know that I need to come up with a partition that has an x, y and z coordinate, right?
Could the equivalence relation be (x,y,z)~(a,b,c) if and only if x^2=a^2?
For the second one, could it be something like (x,y,z)~(0,0,0) if and only if x^2=a^2
Thank you very much
In both cases equivalent points lie on the same plane (sphere). What are the equations of these planes (spheres)?
There are two questions here. Which you talking about?
The equation of any horizontal plane is z= z0. Okay, what must be true of (x1, y1, z1) and (x2, y2, z2) in order that they be on the same plane?
A sphere centered at (0,0,0) has equation x2+ y2+ z2= R2. What must be true of (x1, y1, z1) and (x2, y2, z2) if they lie on the same sphere?
Thank you very much
Z1 and Z2 have to be the same, right? If this is the case, would the partition be something like {{x,y1, n}, {w,y,n}}
A sphere centered at (0,0,0) has equation x2+ y2+ z2= R2. What must be true of (x1, y1, z1) and (x2, y2, z2) if they lie on the same sphere? Doesn't the z coordinate have to be the same?
Thank you
A sphere centered at (0,0,0) has equation x2+ y2+ z2= R2[\sup]. What must be true of (x1, y1, z1) and (x2, y2, z2) if they lie on the same sphere?
No, that was the problem before with planes. If (x1, y1, z1) and (x2, y2, z2) lie on the same sphere then they must both satisfy the equation of that sphere: x12+ y12+ z12= R2 and x22+ y22+ z22= R2 so
x12+ y12+ z12=x22+ y22+ z22.
Thank you very much
Regards
What is Partition on R^3?
Partition on R^3, also known as partition of unity, is a mathematical concept used in the field of topology. It involves breaking a topological space into smaller and overlapping sets, using a set of functions that sum up to 1 over the entire space. This allows for the creation of smooth and continuous functions on a complex space.
What is the purpose of Partition on R^3?
The purpose of Partition on R^3 is to allow for the smooth and continuous manipulation of complex objects or spaces. It is often used in differential geometry and topology to create smooth functions over curved surfaces or manifolds. It also helps in solving problems related to partial differential equations.
How is Partition on R^3 used in practical applications?
Partition on R^3 has various practical applications, especially in the fields of computer graphics, physics, and engineering. It is used to model and analyze complex systems such as fluid dynamics and electromagnetism. It is also used in computer graphics to create smooth and realistic 3D animations and simulations.
What are the benefits of using Partition on R^3?
Partition on R^3 allows for the creation of smooth and continuous functions, making it easier to analyze and solve complex problems in mathematics and other fields. It also helps in simplifying calculations and reducing errors. Additionally, it enables the manipulation of complex objects or spaces without the need for complicated mathematical formulas.
Are there any limitations or drawbacks of using Partition on R^3?
One limitation of Partition on R^3 is that it only works for topological spaces that can be covered by a finite number of sets. It also requires a set of continuous functions that sum up to 1, which may not always be easy to find. Additionally, it may not always provide an exact solution to a problem, but rather an approximation.
