What Happens When an Object Is Dropped from the ISS?
  • Thread starter Thread starter officialmanojsh
    Iss Path
When an object, like a wooden spoon, is released from the ISS, it will initially orbit Earth at a constant distance if released at zero relative velocity. If given an impulse, its trajectory may change, potentially leading it to enter the atmosphere or impact Earth, depending on its angle of entry. Tidal forces from Earth can affect the spoon's orbit, causing it to either decrease or increase its distance from the station over time. The spoon's behavior is influenced by the differential gravity experienced at its release point, which can result in an elliptical orbit if released below the station. Understanding these dynamics is essential for satellite attitude control and orbital mechanics.
officialmanojsh
An astronaut on a revolving space station releases a wooden spoon out of the satellite, into empty space. Will the spoon fall toward Earth ? What will happen next ?
If released at zero relative velocity, it will orbit earth, staying at a constant distance from the station. If given an impulse instead, it will take a different orbit, which may or may not hit Earth's surface (or cause it to enter the atmosphere and either rebound or burn depending on angle of entry I think). There should be some difference though if we take into account the tenuous atmosphere at the station's orbit which may slow down the spoon more (or less) than it does the station, but this would be a long term effect.
I would say the distance will either decrease due to the gravity of the station and the tidal forces of Earth or it will increase due to the tidal forces of Earth, but I'm to lazy to calculate it.
What do you mean with "revolving"?
An astronaut is released from the ISS every time the astronaut stops touching the walls. What happens next?
Well, tidal forces mean differential gravity. So if the spoon is released below the station it will be moving marginally too slow for a circular orbit, which should give it a slightly elliptical orbit with a periodic movement relative to the station I guess. But if released at the same height as the center of gravity of the station, this tidal force is just the difference required for it to orbit at a constant distance on the same path.
This is the correct answer. It's actually an important phenomenon. You can create a poor man's attitude control system for a satellite by just giving one axis a much larger moment of inertia than the other axes. Not a great attitude control system as you could easily see just by looking at what happens when the satellite moves, but you could keep one side generally pointed at the Earth. (Unless your gravity gradient boom flexes too much in response to temperature differentials and winds up flipping your satellite upside down, which has actually happened before.)
Likes wabbit
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
