PDE for Heat Diffusion Equation
ZedCar
The one-dimensional heat diffusion equation is given by :
∂t(x,t)/∂t = α[∂^2T(x,t) / ∂x^2]
where α is positive.
Is the following a possible solution? Assume that the constants a and b can take any positive value.
T(x,t) = exp(at)cos(bx)
∂T/∂t = a exp(at) cos(bx)
∂^2 T/∂x^2 = -b^2 exp(at) cos(bx)
As a, b and α are all positive this cannot be a solution.
A friend and I were working on this and got the answer above. Though as it was about a week ago I can't exactly remember what we've done here.
In the first step I think we've differentiated exp(at) with respect to t, treating the cos(bx) as a constant multiplier, which become a exp(at) cos(bx).
Is that all correct above?
Then we differentiated again with respect to t.
So wouldn't that become;
∂^2 T/∂x^2 = a^2 exp(at) cos(bx)
Why did we previously get ∂^2 T/∂x^2 = -b^2 exp(at) cos(bx)
Thanks!
That first "t" should be "T". I realize this is a typo.
Why?
Yes, but the second derivative with respect to t is irrelevant. Your differential equation has only the first derivative with respect to t.
Because that is the correct second derivative with respect to x, not t.
Thanks!
The first derivative with respect to t is a exp(at()cos(bx). If the differential equation ∂T/∂t= a∂^2T/∂x^2 were satisfied by exp(at)cos(bx) you would have to have
aexp(at)cos(bx)= -ab^2exp(at)cos(bt) which would imply a= -ab^2 which in turn gives 1= -b^2 so b^2= -1 which is impossible for real valued b.
Cheers for that! I see what I was doing wrong - getting x and t confused...
Another possible solution we investigated for the same heat diffusion equation was;
T(x,t) = exp(-at + ibx)The PDEs being;
∂T/∂t = -a exp(-at + ibx)
∂^2 T / ∂x^2 = - b^2 exp(-at + ibx)So the possible solution is possible if a = b^2 α
I understand all the above now.
Though apparently T(x, t) is complex in this instance. How is this apparent?
Thanks!
Be very glad that a, b > 0 does not give a solution, since such a "solution" would violate some basic laws of Physics: warm regions (where cos(bx) > 0) would get hotter, and cool regions (where cos(bx) < 0) would get colder, so heat would flow from cold to hot without any external influence---violating Thermodynamics. Also, warm regions would eventually get hotter than the hottest star, and cold regions would plunge well below absolute zero.
Look instead, at the case a < 0, b > 0. Does that behave properly?
RGV
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
