Percent of solution
  • Thread starter MichaelXY
[SOLVED] Percent of solution
Let's say we have 5% glucose of a 10 mL solution. So that would imply that .5 mL of the solution is glucose, but that does not really tell me how much glucose. Is it assumed that the glucose is 1 molar?
I ask because in one of my bio labs we did a lab where we were given exactly as stated above. Knowing the exact amount of glucose was not needed for the lab, however, I would like to understand this for future use.
Thanks for any input.
Answers and Replies
Yeah, the post above mine tells you exactly what you need to do.
Okay, let's see if I got this right. Since the solute is H2O, I assume 1 molar H2O.
Since 1 mole H2O = 18 grams/mole and I use the molarity formula to get grams.
10mL of H20 or .01L x 1 molar = .01 grams of H20.
ergo .01g H2O x 5% = 5 x 10^-4 gram glucose, or .0005 gram.
Is that correct?
Thanks in advance
yes now if only someone would help me for christ's sake...
I wish I could, but as you can see, I am not that good at chem. Thanks for the assist :)
symbolipoint
Education Advisor
1,242
You probably need to use units of percent weight/volume of solution. The glucose solution is not sensibly prepared as volume of glucose solid per volume of solution.
So by that you mean, Mass of solute/100 mL solution? So I think that would equate to .5 gram C6H12O6 @ 10mL Does that sound correct?
symbolipoint
Education Advisor
1,242
That would give you 5 percent weight per volume.
Related Threads on Percent of solution
  • Last Post
15K
10K
  • Last Post
  • Last Post
15K
  • Last Post
  • Last Post
