Percentage of Block Energy Dissipated
  • Thread starter Thread starter Masrat_A
    Block Energy
The discussion focuses on calculating the percentage of energy dissipated by a block due to air resistance during a vertical fall. The block's speed increases from 6 m/s to 8 m/s over a distance of 3 m, leading to a final energy calculation. The attempt at a solution uses the kinetic and potential energy equations to find that 33% of the block's energy is dissipated. The calculations are confirmed as reasonable by participants in the thread. Overall, the analysis effectively addresses the energy dissipation due to air resistance in the given scenario.
Masrat_A
During a vertical fall, a block's speed increases from 6 m/s to 8m/s over a 3 m distance. What percentage of the block's energy is dissipated due to air resistance over this distance?
##E_f = E_i##
##E_f = DE_i##
##KE_f + PE_f = D(KE_i + PE_i)##
##1/2MV_f^2 + 0 = D(1/2MV_i^2 + Mgy)##
##V_f^2 = D(V_i^2 + 2gy)##
##64 = D(36 + 60)##
##D = 0.67##
##1 - 0.67 = 0.33##
##0.33 * 100 = 33##
I wasn't so sure on what to label dissipated energy, so I went with D. Does any of this seem reasonable?
It's all very reasonable.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
