Which Element Has These Successive Ionization Energies in Period 3?
The discussion revolves around identifying a Period 3 element based on its successive ionization energies: 1800, 3000, 3600, 5800, and 13200 kJ/mol. Participants suggest looking up the ionization energies of the eight Period 3 elements. The consensus leans towards Silicon as the likely candidate due to the significant jump between the fourth and fifth ionization energies, indicating a change in the electron configuration. This large gap is characteristic of Silicon, confirming its identity in this context.
Kelly09
i am stuck on this question and people are giving me different answers. Ok which period 3 element has the following succesive ionization energies: 1800,3000,3600,5800,13200
Chemistry news on Phys.org
Just look up the ionization energies of all of the period three elements... there's only 8...
I would guess Silicon, because of the large gap between fourth and fifth energies...
thankyou
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
