Phase Angle for Simple Harmonic Motion
In simple harmonic motion, the phase angle, denoted as φ, remains constant when deriving equations for displacement, velocity, and acceleration, as it is independent of time. The term "phase" refers to the entire expression (ωt + φ), which changes over time, while φ itself is a constant. The phase constant φ does not involve any actual angle measurement in the context of simple harmonic motion. When the displacement reaches its maximum value, the phase is equal to 2kπ, where k is an integer, and it equals zero when ωt + φ is (k + 1/2)π. Understanding these distinctions clarifies the relationship between phase and phase angle in simple harmonic motion.
mneox
Phase Angle / Phase Question - Simple Harmonic Motion
If I were given a function of displacement for simple harmonic motion in the form of:
x = Acos(\omegat + \phi)
Would the phase angle, \phi, always be the same? Say if I derived the equations into forms for velocity and acceleration as well. The phase angle would not change.. is that correct?
Also, I am confused about what is the phase and what is the phase angle? My textbook lists the "phase angle" as \phi and some other sources list "phase" as (\omegat + \phi). What's the difference between these??
v = -\omegaAcos(\omegat + \phi)
a = -\omega2Acos(\omegat + \phi)
My belief is that it wouldn't change, but I want to be 100% sure.
Thanks for your clarification!
Hi, sorry to "bump" a thread but it's been a while now and I still want some clarity on this. Can anyone offer help?
As far as your first question is concerned, phase does not change if you take derivative of 'x' as long as the phase is independent of time.
It is better to call Φ "the phase constant" It is not really angle, as no angle is involved in the SHM. Φ does not change if you calculate the time derivatives of the displacement. The phase is ωt+Φ. It depends on time. When x=Acos(ωt+Φ) has its maximum value the phase is 2kΠ (k is integer). And x=0 if ωt+Φ=(k+1/2)Π . ehild
