Phase Changing substance: me out
  • Thread starter Thread starter tkdpainkiller
    Phase
A student seeks a substance that can transition from solid to a semisolid or high-viscosity liquid state through UV light or electrical stimulation. The discussion highlights that typically, temperature and pressure are the primary factors influencing a substance's state. One suggestion involves heating an ionic compound to its melting point and using a strong electrical current to keep it molten. Additionally, electro-rheological (ER) fluids are mentioned as a potential solution for achieving the reverse transformation from liquid to solid. These insights focus on the manipulation of material states through external stimuli, emphasizing safety and practicality for handling.
tkdpainkiller
I am a student trying to find a substance whose state I can control using either UV light or electicity. Preferrably, it would be solid at room temperature, but exposure to some sort of stimulus would cause it to change into a "semisolid" or liquid with high viscosity. As I am not knowledgeable in chemistry, there's no way I can find this on my own. If you know of such a substance (preferrably one that can be handled safely), please let me know.
Thanks,
Nick
Chemistry news on Phys.org
I may be wrong but for pure substances temperature and pressure are the only variables that affect their state.
The only somewhat related idea I can think of is to heat an ionic compound to its melting point and then use a strong electrical current to maintain its molten state.
The reverse effect (liquid to solid transformation) can typically be achieved in an ER (electro-rheological) Fluid. Google it and see if that will work for you.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
