Phase Locked Loops: Coherent vs Non-Coherent Detection, PLL & 2*pi Rotation
  • Thread starter Thread starter janu203
    Loops Phase
Coherent detection involves phase-locking an oscillator to the carrier of a received signal, allowing for the detection of modulated information while retaining the absolute phase. In contrast, non-coherent detection does not track the carrier's phase, as seen in envelope detectors for AM signals. Phase shift and phase rotation are effectively the same, with a 2π radian rotation equating to a full 360° rotation, resulting in no net effect. Understanding these concepts is essential for grasping the functionality of Phase-Locked Loops (PLLs). Further reading on these topics is encouraged for a deeper comprehension.
janu203
what is difference between coherent and non-coherent detection? and what is a PLL? secondly what is meant by 2*pi phase rotation? is it same as 2*pi phase shift? thanks in advance
PLL. By measuring the difference in phase between an oscillator and a signal carrier, the oscillator can be adjusted to lock onto the phase of the signal. http://en.wikipedia.org/wiki/Phase-locked_loop
A coherent detector phase locks an oscillator to the carrier of the received signal. It then effectively multiplies the received signal by the oscillator to detect the modulated information. It retains the absolute phase of the modulation.
A non-coherent detector does not track the signal carrier's phase. One example is an envelope detector for AM.
Phase shift and phase rotation are effectively the same.
A 2*Pi radian rotation is a 360° rotation, so it has no net effect.
Modulation is often described as a “phasor” which is a directional vector. http://en.wikipedia.org/wiki/Phasor
Likes 1 person
Please check your PMs.
Please do some reading on your own before asking overly broad questions here. We expect to see that you have put some effort into answering your questions. You have been given some great resources by Baluncore -- please read through the links, and then ask specific questions about that reading if you still have questions.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
