Physics Homework for answers/also explain how to do them
The discussion centers on solving physics problems related to velocity and displacement. The first problem involves calculating the average velocity of a trip where the car experiences a slowdown due to engine issues. The second problem requires graphing the motion of two cars and determining when the faster car overtakes the slower one. The third problem focuses on the time it takes for a bullet to hit a target and converting its speed to kilometers per hour. Overall, the conversation emphasizes understanding the relationships between distance, speed, and time through various equations.
hstudent321
Physics really stumps me, I try to study a lot but its not getting in my head... Anyway here are the questions i need help on. I tried doing the problem out but it confuses me.. SO far I'm going over velocity, displacement, like V=d/t and D=vt t=d/v
1) You drive your Miata from home at an average velocity of 80 km/h for 3 hrs. Halfway to your destination, your Miata develops some engine problems, and for 5hrs you "nurse" the car the rest of the way. What is your average velocity for the entire trip?
2) Two cars are headed in the same direction; one traveling 60 km/h is 20km ahead of the other traveling 80km/h.
A)What would the graph look like showing the motion of the two cars?
B) When does the faster car overtake the slower one?
3) A bullet is fired with a speed of 720.0 m/s.
A) What time is required for the bullet to strike a target 324 m away?
B) What is the velocity in km/h
You got to know the distance from Miata to home to do that question. The word 'nurse' implies you are going slower and so need to calculate the speed after stopping.
2)
a) plot a graph on a piece of paper with speed/velocity on the side and time on the bottom (i'd just put 1hr, 2hr, 3hr etc for each of the velocities [unless you got given something])
b) those 3 equations that you have are just different ways of writing the same thing.
anyhow you have two velocities v1=60km/hr v2=80km/hr, when the cars pass each other t will be the same for both cars. so put both with respect to t (t=d/v). write out 2 equations so because the t's are the same d1/v1=d2/v2. you should be able to work this out from here.
3)
a) v=720m/s, d=324m -> you have an equation (t=d/v just sub the values in)
b) v=720m/s
1km=1000m -> 1km/1000m = 1
1hr=3600s -> 3600s/1hr =1
(you don't want to change the value so you need to multiply by 1)
720m/s x 1km/1000m x 3600s/1hr (so 720m/s x 1 x 1)
so this will cancel m and s and you'll be left with km/hr
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
