Physics Homework Question on Electrostatic forces
The discussion centers on a physics homework question regarding the electrostatic forces acting on a charge q inside a spherical balloon with surface charge. The correct answer is that the electrical force on the charge is zero everywhere inside the balloon, which is explained by applying Gauss' Law. The reasoning highlights that the charge distribution on the balloon's surface creates an electric field that is effectively zero within the interior. Participants clarify that the assumption of a continuous charge distribution is key, as opposed to a quantized charge model. This principle is consistent with most static electricity scenarios encountered in physics.
somerandomuser
Charge is distributed on the surface of a spherical balloon (an insulator). A point particle with charge q is inside. If polarization effects are negligible the electrical force on the particle q is greatest when:
a. it is near the inside surface of the balloon
b. it is at the center of the balloon
c. it is halfway between the balloon center and the inside surface
d. it is anywhere inside (the force is same everywhere and is not zero)
e. it is anywhere inside (the force is zero everywhere)
F = kqq/r^2
I thought it would be "a" because their would be more differences in forces the closer the charge is to the surface.
The correct answer is "e". I do not understand why :(.
Difference in what forces?
Due to which thing will the charge q experince a force? What is necessary for a charge to experience force?
If you apply Gauss' Law, what electric field is produced inside of the balloon
due to a uniformly distributed charge on the surface of the balloon?
I suspect OPs reasoning is due to charge being quantized but need feedback to be sure.
Ya my reasoning was because I thought charge is quantized.
The question assumes the situation where charge is well approximated as a continuous fluid... i.e. the net charge is very much larger than the charge quanta, and the scale is such that the description of the surface as "a sphere" still makes sense (as opposed to, say, an array of nuclei in a cloud of electrons). In that approximation, the field inside the classical surface is everywhere zero.
This is usually the case unless you are told otherwise, and holds extremely well for almost every real-life static electricity problem.
