[Physics Honors] Finding magnitude
  • Thread starter Thread starter choco1drop
    Honors Magnitude
A 60 N block on a 30-degree ramp requires a horizontal force to prevent movement. The normal force was calculated as 51.96 N, and the net force was confirmed to be zero. The user initially calculated the required horizontal force as 25.98 N, while the correct answer is 35 N. The discrepancy arose from not accurately accounting for the gravitational force component along the ramp. The solution involves ensuring that the horizontal force component matches the gravitational force component acting down the ramp.
choco1drop
A 60 N block sits on a ramp slanted at 30 degree. A horizontal force is applied to the block to prevent it from moving. What is the magnitude of the force?
I found the normal force to be 51.96 N (checked it with the answer) and the net force to be 0 (checked with answer as well). But the last part, finding the magnitude of the horizontal force, doesn't seem to make sense to me.
The answer says it's 35 N, but what I got was 25.98 N. picture I tried to draw to show what i did --- > http://puu.sh/bZVT5/0d077890a0.png
I used relative triangles and geometry to determine the angles. Any help would be appreciated on where I went wrong. Thank you.
I don't know how to delete threads, but I figured out how to find the solution to this problem.
You have found the component of the force of gravity along the ramp. The component of the horizontal force along the ramp must cancel this exactly.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
