Finding Reactions in a Pinned and Roller Supported Beam
  • Thread starter Thread starter andycampbell1
    Frames
The discussion focuses on determining the reactions at supports A, B, and C, as well as at internal pin P for a beam with specified loading conditions. The user successfully calculated the reactions at pin P (+4.00 kN) and support C (+6.00 kN) using moment equations. They encountered difficulties in finding the vertical reactions at supports A and B, initially using incorrect moment calculations. After revising their approach and including all forces, they derived the correct reactions: VA as +3.87 kN and VB as +13.12 kN. The conversation emphasizes the importance of including all forces in moment calculations for accurate results.
andycampbell1
The beam ABC in attachment has a pinned support at A and Roller supports at B and C. P is an internal pin. I have to determine the reactions at A, B and C and at the pin P when the beam is loaded as shown in the attachment
\SigmaV=O \SigmaH=0
I have split the problem in half and started with the right hand side. I have worked out the reaction at the pin as +4.00 kN and the reaction at C as +6.00 kN. I have done this by taking the moments of P as (10x3)-VC*5=0. I then worked out the sum of the vertical which = 0 to get the reaction at the pin that was VP-VC-10= 0 meaning that VP =+4.00 kN. I have worked out the horizontals on the left by doing the sum of the horizontals = 0, \SigmaH=0
=HA-15cos60=0 HA= +7.5kN. What I would like to know is how to find out the vertical reaction at A and B Thanks
andycampbell1: Nice work, so far. Hint 1: For the left-hand side, take moments about point A or B.
I have tried taking the moments of A. The book I am working from gives me the answers for VA as +3.87kN and VB as +13.12kN. For taking moments about A I tried this
\SigmaMA=0
=2.5x15sin(60)-VBx4=0.
I have also tried adding VBx4 and adding the value of the pin and dividing by the length of 5 but I cannot come up with what the book states as the answer. Would I be as well to keep this as 2 separate structures for taking the moments of A or using the whole structure?
Keeping this as two separate structures for taking moments is good, if you wish. Either way you prefer is fine. Your MA summation, above, omitted VP. You cannot omit forces on your structure (or on your sectioned-off portion of a structure). Also, see the last paragraph of post https://www.physicsforums.com/showpost.php?p=2946515".
Hi finally managed to get it, this is what I done
\SigmaMA=0
=(2.5x15sin60)+(VPx5)-VBx4)=0
=(32.48)+(20)-(VBx4)=0
VB=+13.12 kN
\SigmaV=0
=VA+VB-15sin60-VP=0
= 0 + 13.12 - 12.99 - 4 = 0
VA = +3.87 kN
Thanks for the links they have helped me.
