Plane drops packages confounded again
  • Thread starter Thread starter Phoenixtears
    Plane
A supply plane dropping a package from 108 m above a glacier in Greenland requires calculations for the drop distance and impact speed. The plane's speed is 175 m/s, and the challenge lies in separating horizontal and vertical motions to determine the time of fall. Using the equation for vertical motion, the total falling time can be calculated, which then allows for determining the horizontal distance traveled. The discussion emphasizes the importance of treating horizontal and vertical components independently to solve the problem effectively. The participant ultimately resolves their confusion and is able to answer the remaining questions.
Phoenixtears
A supply plane needs to drop a package of food to scientists working on a glacier in Greenland. The plane flies 108 m above the glacier at a speed of 175 m/s.
How far short of the target should it drop the package?
m
What speed does the package have when it hits the ground?
m/s
In what direction is the package moving when it hits the ground?
degrees below the horizontal (or the "x" axis).
Vf= V0 +at
Deltax= V0t+ .5at^2
Vf^2= V0^2 +2ax
SOHCAHTOA
I can't seem to figure out enough information for this to work. The horizontal acceleration always being zero is halting me from attaining more info. The verticle motion is the same, except with even less. I have only the change in x and the acceleration. I wish to find the time as well, but it seems rather impossible.
Suggestions?
In these kind of problems, you always consider the horizontal and the vertical problem separately. The general way to handle them is:
- In the vertical direction, use something like y = h - 1/2 g t^2 to find the total falling time tf
- In the horizontal direction, the velocity vh is constant, so the horizontal distance traveled is vh * tf.
For the first question, that approach will work.
Gotcha. Figured out what I was doing wrong. Thanks!
Did that also help you answer the other questions?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
