What is the minimum height for a mirror to see full image?
  • Thread starter Thread starter Dars
    Mirror Plane
To see a full image in a mirror, the minimum height of the mirror should be half the height of the person, which is 1 meter for a 2-meter tall individual. This is because a plane mirror reflects light at equal angles, allowing the viewer to see their full reflection without needing the mirror to be the same height as themselves. Drawing a ray diagram can clarify how light reflects and aids in understanding the concept better. Many participants in the discussion emphasize the importance of visual aids in solving this problem. A proper understanding of reflection principles is essential for determining the minimum mirror height.
Dars
I am 2 meters tall and I want to see my full image in a mirror. What is the minimum height the mirror should be?
Why shouldn't min height be also 2m, because no magnification (plane mirror) ??
Here, drawing a ray diagram would really help, because I have seen a lot of confusion among guys about this question... so draw the RD and post it here, and believe me, it helps a lot.
