exitwound
- 291
- 1
Two large metal plates of 1m^2 are separated by a distance .05m^2 and carry equal and opposite charges on their inner surfaces. If E between the plates is 55 N/C, what is their charge? Neglect edge effects
\int \vec{E}\cdot d\vec{s}
\epsilon_0EA=Q
First of all, can I ask if the Electric Field between the plates is equal to \frac{2\sigma}{\epsilon_0}? It might not be relevant to the problem, but I don't even know if my attempt at the calculations from this point on would be accurate if it's not. It looks like the effect of a particle from the positive plate would be \frac{\sigma}{\epsilon_0} and the effect from the negative plate would be \frac{\sigma}{\epsilon_0} as well. Therefore, the Electric field is the sum of the two fields, or \frac{2\sigma}{\epsilon_0} in the direction of the negative plate.
If I slap the values in the second equation mentioned above, the correct answer of 4.9x10^-10 C comes out. However, I don't understand where that equation comes from in terms of this problem.
\epsilon_0EA=Q
(8.85x10^-12)(55)(1)=4.9x10^-10 C
I'm completely lost on the reasoning once again or the application of Gauss's Law (the chapter this problem comes from) on the problem.
