Please explain this from a text book
The discussion revolves around concepts from electromagnetic theory as presented in "Antenna Theory" by Balanis, specifically focusing on the mathematical relationships between electric and magnetic fields, vector potentials, and the far-field approximation. Key points include the derivation of the electric field from the vector potential, with emphasis on the far-field zone where only the leading order term in a multipole expansion is relevant. Participants express confusion over specific equations and the rationale behind Balanis's approach, particularly regarding the treatment of terms involving 1/r^n. The conversation also touches on the importance of gauge conditions, such as the Lorenz gauge, and the implications for solving Maxwell's equations in different contexts. Overall, the thread highlights the complexities of electromagnetic field theory and the need for further study on multipole expansions and gauge transformations.
yungman
See attached scanned pages of page 118(left side) and page 125(right side) of Antenna Theory by Balanis.
On the left side, it is just some basic EM where
\nabla\times \vec E=-\frac{\partial \vec B}{\partial t}\;\Rightarrow\;\vec E=-\nabla V-\frac{\partial \vec A}{\partial t}
Then to Lorentz thingy ##\nabla\cdot \vec A=-\mu\epsilon \frac{\partial V}{\partial t}##.
And so on...
The only thing different is it is in time harmonic form where ##\frac{\partial}{\partial t}\rightarrow\;j\omega##.
Now going to the right side. I underlined the sentence that I have no idea where that comes from! What is ##\frac {1}{r^n}=0## where n=,2,3,4...
Please explain what is that. This supposed to be very basic thing that
\vec B=\nabla\times\vec A
Then for far field where it is assumed plane wave,##\vec E=\eta\hat R \times \vec H##
This is a very basic knowledge of finding E and H from A. Where is all the what looks like numerical stuff come from?
Please help.
Thanks
Anyone?
If you look at (3-58a) \tilde {E}=-j\omega \vec{A}
This is nothing more than
\nabla\times \vec{E}=-\frac{\partial{\vec{B}}}{\partial{t}}=-\nabla \times \frac{\partial{\vec{A}}}{\partial{t}}\;\Rightarrow\;\nabla\times \vec{E}+\nabla \times \frac{\partial{\vec{A}}}{\partial{t}}=0\;\Rightarrow\;\nabla\times\left[\vec{E}+\frac{\partial{\vec{A}}}{\partial{t}}\right]=0
\Rightarrow\;\vec{E}=-\frac{\partial{\vec{A}}}{\partial{t}}=-j\omega\vec{A}
Why all the fuzz?
This seems to be a somewhat messy book, to say it friendly ;-). Anyway, what the authors means is that in the far-field approximation (i.e., the em. field in a region very far from the charge and current distributions causing this field) you can perform an expansion in powers of 1/r. This is equivalent to the decomposition into spherical waves (multipole expansion). In the leading order you are left with the pure dipole component (except for the special case that the charge-current distributions are such that the field starts at higher order, but I guess that subtlety you can neglect for the moment).
Likes 1 person
Thanks for the reply. Under what topic can I find more info? Is it "multi pole expansion" or some other name? Do you have link for some article? I have not study this before.
You think I can ignore all these and use what I have in post #2?
Thanks
For harmonic time dependence, i.e.,
\vec{E}(t,\vec{r})=\exp(\mathrm{j} \omega t) \vec{E}'(\vec{r}),
and for all other fields too, you have
\vec{E}=-\vec{\nabla} \vec{\Phi}-\partial_t \vec{A}
gives
\vec{E}'=-\vec{\nabla} \Phi'-\mathrm{j} \omega \vec{A}'
etc.
For the Lorenz (it's the Danish physicist Ludvig Lorenz who was the first to simplify Maxwell's equations by the gauge condition) gauge you have (for \mu=\epsilon=1)
\Box \Phi=\rho, \quad \Box \vec{A}=\vec{j}
which translates into
(-\Delta - k^2) \Phi'=\rho', \quad (-\Delta-k^2) \vec{A}'=\vec{j}'
with k=\omega/c.
The wave equation thus translates to the Helmholtz equation for harmonic time dependence.
Likes 1 person
Thanks, I have to do some reading. Can I ignore these and just use what I posted in post #2?
Edit: I found a chapter in Griffiths Introduction to Electrodynamics page 146 on Multipole Expansion.
Can anyone tell me why Balanis going through all the fuzz? What's wrong with the way I did it in this quote?
I don't understand your reasoning. Let's do it systematically.
You start with the homogeneous Maxwell equations (for simplicity I use Heaviside-Lorentz units with c=1 and consider all fields in the vacuum):
\partial_t \vec{B}+\vec{\nabla} \times \vec{E}=0, \quad \vec{\nabla} \cdot \vec{B}=0. \qquad (1)
The last equation implies the existence of a vector potential, such that
\vec{B}=\vec{\nabla} \times \vec{A}. \qquad (2)
Using this in the first equation implies
\vec{\nabla} \times (\partial_t \vec{A}+\vec{E})=0.
This implies that the field in the bracket has a scalar potential (at least locally)
\vec{E}=-\vec{\nabla} \Phi-\partial_t \vec{A}. \qquad (3).
For a given em. field (\vec{E},\vec{B}) the potentials are not uniquely defined, but you can always use
\vec{A}'=\vec{A}-\vec{\nabla} \chi, \quad \Phi'=\Phi+\partial_t \Phi
with an arbitrary scalar field \chi (gauge invariance of Maxwell's theory).
As we'll see in a moment, it's very convenient to (partially) "fix the gauge" by demanding the Lorenz gauge condition,
\partial_t \Phi+\vec{\nabla} \cdot \vec{A}=0. \quad (4)
Now you can consider the "inhomogeneous" Maxwell equations.
-\partial_t \vec{E}+\vec{\nabla} \times \vec{B}=\vec{j}, \quad \vec{\nabla} \cdot \vec{E}=\rho.
Using (2-4) you find
\partial_t^2 \vec{A}-\Delta \vec{A}=\vec{j}, \quad \partial_t^2 \Phi-\Delta \Phi=\rho. \qquad (5)
For harmonic time dependence, i.e., writing all fields in the form
F(t,\vec{x})=\exp(\mathrm{j} \omega t) F'(\vec{x}),
you find from (2) and (3)
\vec{E}'=-\mathrm{j} \omega \vec{A}'-\vec{\nabla} \Phi', \quad \vec{B}'=\vec{\nabla} \times \vec{A}',
and from (5)
-(\omega^2+\Delta) \vec{A}'=\vec{j}', \quad -(\omega^2+\Delta) \Phi'=\rho'.
This is the starting point to solve the problem of the radiation from a given charge-current distribution for harmonic time dependence. From this you get more general cases, using the technique of Fourier transform.
Likes 1 person
Thanks, I have to take a little time to work through this.
yungman said:
Anyone?
Why all the fuzz?
I reviewed multipole expansion and come back, here. I see what I did wrong.
\vec{E}=-\nabla \Phi-\frac{\partial{\vec{A}}}{\partial{t}}=-\nabla \Phi-j\omega\vec{A}
How do I get to
\vec{E}=-j\omega\vec{A}
I don't know, how you got there. Perhaps, you've constraint the Lorenz gauge condition further to radiation gauge, which you can do in the source-free region. The radiation gauge conditions are
\Phi=0, \quad \vec{\nabla} \cdot \vec{A}=0.
This is in the attachment in the original post. I have studied the multipole expansion, it doesn't seem to help. I am at a lost. I yet have to review Gauge transformation, just barely finish the multipole today. Please help.
Thanks
How do I get to
what you have written is valid only in the radiation zone i.e. far field zone.In this zone only 1/r contribution survives,all other higher powers are neglected.If you will compare 3.57 to 3.56,you will immediately see the result.
Yes, this is exclusively in the far field zone only. Problem is I don't know how to derive 3.55-3.57
Can anyone show me how to derive 3-56 and 3-57 from 3-55? That would really help.
Thanks
To get 3.56,you have to solve helmholtz eqn i.e. the eqn which is satisfield by A.You also have to use an expansion of 1/|x-x'| to get all those 1/rn terms and then you will have to just put it into 3.15 to get E.Let me see if I can find a proper reference(I remember Jackson has treated something similar in the chapter on waveguides).
EDIT-Somewhat useful here
Likes 1 person
Thanks for the info. Wow, this is a lot of study for me. This is beyond what I studied. I only studied Griffiths and two other Engineering EM books which is even simpler than Griffiths in this part. They are more concentrated on transmission lines etc. instead.
Regarding to the article, can you:
1) give me some info how to get
\vec A(x,t)=\frac{\mu_0}{4\pi}\int d^3x'\int dt'\frac{\vec J(x',t')}{|\vec x-\vec x'|}\delta\left(t'-t+\frac 1 c|\vec c-\vec x'|\right)
2) Is ##\delta\left(t'-t+\frac 1 c|\vec c-\vec x'|\right)## a Dirac Delta function? where
##\delta\left(t'-t+\frac 1 c|\vec c-\vec x'|\right) = \begin{cases} +\infty, & \left(t'-t+\frac 1 c|\vec c-\vec x'|\right) = 0 \\ 0, & \left(t'-t+\frac 1 c|\vec c-\vec x'|\right) \ne 0 \end{cases} ##
3) What is ##\int d^3 x'##?
4) Can you give me the pages of JD Jackson that talk about this subject? I have the book at home, but I am out of town so I can't get to it. I am just trying very hard to understand how to get to ##\vec E=-j\omega\vec A##. Is there an easier to get to this?
Thanks
This may not be what you're looking for, but here's how I understand the idea of far field radiation. Maybe it'll help you find what you're looking for...
We know that the amplitude of the Poynting vector is \left| \vec{E}\times\vec{H} \right| which is proportional to \left| \vec{E} \right|^2. So the power per unit area is proportional to \left| \vec{E} \right|^2. If we integrate the power over the surface of a sphere of radius r, we'll get a total power which is proportional to 4\pi r^2 \left| \vec{E} \right|^2. So if the amplitude of \vec{E} is proportional to 1/r^n, then the total power over a sphere of radius r is proportional to r^2/r^{2n}.
If you take the limit r \to \infty (far field), you see that the total power is zero for any terms with a 1/r^n dependence where n>1. You also see that any terms with a 1/r^n dependence where n\leq 0 make no sense because they give you infinite power in the far field. Finally, any terms with a 1/r dependence give you a finite total power at the far field. So we call these the "far-field" terms, because they're the only terms which give us a finite, non-zero total power through any closed surface which is very far from the source. I think that's all he's really saying here.
Now, here's something I'm guessing at which will maybe help you figure out the more "rigorous" aspect of this, but I'm definitely not confident about it:
I *suspect* that the idea of breaking down a wave into 1/r^n components isn't actually very useful in general. The reason I think this is that the more "natural" way to break things down in spherical coordinates would be to use spherical harmonics, which are based on stuff like bessel functions and legendre polynomials. They would have nice properties like orthogonality which the 1/r^n "basis" would not. Orthogonality makes it much easier to break a function down into a sum of those components. (That's the advantage of using Legendre polynomials instead of just 1, x, x^2, x^3, \ldots). So trying to find all the 1/r^n terms might not be very fun.
That said, in the case of finding far-fields, you don't need all the terms because you're killing off everything except for the 1/r term. So in that case, all that matters is the fact that you could break things down into a 1/r^n sum. You don't need (or want) to know how to actually do that in general. Of course, the advantage of using a 1/r^n decomposition rather than a spherical harmonic decomposition for far-fields comes from what I discussed about power above. With spherical harmonics, I *think* (not 100% sure) that the disadvantage is that all the components carry some power out to infinity and lose some power along the way, so to find the field at r \to \infty, you'd have to worry about every single term. The easier way is to say "I could break things down into a 1/r^n sum," and then argue that only the 1/r term would survive at infinity, so you only have to worry about that one.
Like I said, I'm not completely sure about that because I'm not an expert on spherical harmonics, but what I said seems reasonable to me. Maybe it'll at least help you find an explanation you can be confident in.
Likes 1 person
gives
etc.
with k=\omega/c.
I am reviewing the gauge transformation and study back what you wrote:
\Box \vec A=\frac {1}{c^2}\frac{\partial^2 \vec A}{\partial t^2}-\nabla^2\vec A=\mu_0\vec J\;\Rightarrow\;(-\nabla-k^2) \vec{A}=\mu_0\vec{J}
\Box V=\frac {1}{c^2}\frac{\partial^2 V}{\partial t^2}-\nabla^2V=\frac{\rho}{\epsilon_0}\;\Rightarrow\;(-\nabla-k^2) V=\frac{\rho}{\epsilon}
How come you gave
which in my terms:
(-\Delta - k^2) \Phi=\frac{\rho}{\epsilon_0}, \quad (-\Delta-k^2) \vec{A}=\mu_0 \vec{J}
Do you mean ##\nabla##, not ##\Delta##?
and from (5)
Is this one
supposed to be:
-(\omega^2+\nabla) \vec{A}'=\vec{j}', \quad -(\omega^2+\nabla) \Phi'=\rho'.
I gone through this derivation. How does this bring me any close to my original question? I need to derive (3-56) and (3-57) from (3-55) in my original attachment, and ultimately (3-58). I don't see any relation to my question.
So far, I spent two days studying multipole expansion and today on the Gauge transformation. But I don't feel I am any where closer to derive the equations! Can you tell me what am I missing, how do I tie them together?
Thanks
The relation A(x,t) is determined from the general eqn. ∇2A-(1/c2)∂2A/∂t2=-μ0J.the particular solution is determined using green function,in terms of which
A(x,t)=∫(μ0J)G(x,t;x',t')d3x'dt'→(1)(d3x' is simply the volume element dxdydz).
you have to determine green function for the eqn. using Fourier transform,the green function comes out in terms of delta function and putting into (1) gives that eqn.(you can see chapter 6 of jackson for deriving this green function also see chapter 9)
Likes 1 person
Thanks, I have to go home and read Jackson.
yungman said:
To confirm, ##d^3x'## is just a differential volume like ##dv'## or ##dxdydz##
yes,it is a very wide notation used everywhere in physics.Also I think there is an easy way to get E=jωA.In far zone the electric field is transverse in character(no radial component).You can see that ∇\phi will give a contribution of 1/r2,even if \phi varies as 1/r.Hence you can leave that term and only ∂A/∂t will contribute and you get what is required.
Likes 1 person
So if
V(\vec r)=\frac 1 {4\pi\epsilon r}\int\rho(\vec r')dr'
then
\nabla V(\vec r)\propto \;\frac 1 {r^2}
So for far field, ##r\rightarrow\;\infty##, ##\nabla V## term disappeared and
\vec E=-j\omega \tilde A
Just that simple?! So I don't have to go through Jackson and review Green's Function?
Thanks
yungman said:
So if
then
Thanks
I want to double verify this as I can move on using this assumption that in far field, ##\;\nabla V\rightarrow0\;\Rightarrow\;\vec E=-j\omega \vec A##.
Anyone?
you should have read it.A(vector potential) contains radial component but does not give a radial component of electric field.Why it does not give,you can figure out it by evaluating it.It cancels.So you should review it.
