Solving Problems with Tension, Overturning, and Friction: Tips and Tricks
  • Thread starter ninjagowoowoo
In summary, the conversation is about three physics problems where the individuals are seeking help and clarification. The first problem involves calculating the tension in a wire based on the weight of a tightrope walker and the sag of the wire. The second problem involves determining the minimum mass needed to cause a round table to overturn, given the placement of three equal distance legs. The third problem involves finding the maximum coefficient of static friction for which a cube will begin to slide instead of tip over, when subjected to a horizontal pull. The conversation also includes discussions about a ladder problem and using the torque equation to solve for unknown forces.
ninjagowoowoo
75
I have a few problems where I just need a push in the right direction:
(1) A tightly stretched "high wire" is 46.5 m long. It sags 3.49 m when a 59.7 kg tightrope walker stands at its center. What is the tension in the wire? I have no idea what to do on this problem...
(2)A 36.6 kg round table is supported by three legs placed equal distances apart on the edge. What minimum mass, placed on the table's edge, will cause the table to overturn? Neglect the mass of the legs. Wouldn't I need to know some other information like radius or something?
(3)A cube of side l = 120 cm rests on a rough floor. It is subjected to a steady horizontal pull, F, exerted a distance h = 83.0 cm above the floor. As F is increased, the block will either begin to slide, or begin to tip over. What is the maximum coefficient of static friction for which the block begins to slide rather than tip? Wouldn't I ned to know F to figure this out? Keep in mind my answer has to be a numerical value, not a formula.
Any tips on any problem would be greatly appreciated. Thank you so much for helping...
(1) The shape of the wire is an isosceles triangle with "height" 3.49 m. You can work out the angles at the two sides (on either side of the tightrope walker), and then resolve forces on the walker (two tension forces + gravity).
Thanks, any ideas on the other questions?
I'm stuck on those last two too...
did you get numbers 5 or 6? My brain just won't work today. The last two questions regarding the damn ladder?
Yeah... I set x and y-axis as they are assigned in the prob, then just found torques. Torques are not perpendicular to the things they are acting on, so you must convert. Most the conversions were cos(theta) i think... although I think one was sin(90-theta). That help?
Haha, I am seriously having a rediculous amount of difficulty with this. Did you use the center of the ladder as your pivot point? Then for torque you're using rFsin(theta) right? Is that what you meant by converting? Is F just the weight of the ladder?... I think I'm just having a difficult time identifying the forces acting on the ladder that contribute to torque.
If you want some help, a problem, or some pictures wouldn't hurt.
Torque = rFsin(theta) is the torque equation
cos(x) = sin(90-x) is a trig identity
The problems I'm most concerned with are in the first post, I just got sidetracked.
See https://www.physicsforums.com/showthread.php?t=72065 for the ladder problem
The problems are pretty self explanitory, but if you want some pics i'd be happy to upload some.
I don't see any ladders in the first three problems.
I just changed my last post, sorry
You've got me on #2 and #3.
yeah they're crazy... I don't know what my professor is thinking.
Ok, the ladder will pivot about its ground contact. The center of mass would just be at the center, or 3.87m from the pivot point. You can find the torque in the counterclockwise direction from there, but keep in mind that the force is not just mg. Now since the torques sum to zero, the wall is providing the same torque but in the clockwise direction.
The forces in the x and y directions both equal 0. The force towards the ground (-y) is F = mgsin(71.4), what can you say about the normal force (in x and y) applied on the ladder?
A similar argument for the wall works.
I picked the point against the wall as the rotation point
squib: Either one works. Now find the torque in the clockwise direction from that point, can you find the force, and radius?
Thanks a lot. I really appreciate all the help, now if only we can find someone that can do the second two probs. I think I'm going to repost them.
On the cube problem I seem to come up with u = (a*h)/(g*(l/2))
My problem is that I can't figure out what a is...
this could also be written u = (F*h)/(mg*(l/2)), F being the constant force...
yeah, I can't find a way to express u without using F or A. Bah.
do you think maximizing F or A would give us an answer? Eg: putting all the constants in, taking the derivative of the whole thing and setting it equal to zero? Then we could use this force to put back into your equations. Does that sound plausible? I think I'll try it.
bah ... darned equation has no max (duh). That doesn't work
the center of mass of the cube is at the centerpoint, or (0.6,0.6)
The force is not being applied through the center of mass, so there is a clockwise torque. Thats just a thought.
Related to Solving Problems with Tension, Overturning, and Friction: Tips and Tricks
What is tension and how does it affect problem solving?
Tension is a force that is created when an object is pulled or stretched. It can affect problem solving by creating a balancing act between multiple forces and determining the stability or instability of an object.
How does overturning occur and what are some strategies to prevent it?
Overturning occurs when an object is not in equilibrium and is unstable. This can happen when the center of gravity is not directly above the base of support. To prevent overturning, you can adjust the position of the center of gravity, increase the base of support, or add additional support structures.
What role does friction play in solving problems involving tension and overturning?
Friction is a force that opposes motion and can affect the stability of an object. In problems involving tension and overturning, friction can help to prevent sliding or slipping of an object by providing a counteracting force. It can also be used to increase stability by increasing the overall frictional force.
What are some common mistakes people make when solving problems involving tension, overturning, and friction?
One common mistake is neglecting the effects of friction in the problem. Friction can greatly impact the stability of an object and should be taken into account. Another mistake is not properly accounting for all the forces acting on an object, leading to an incorrect solution. It is also important to double check calculations and assumptions before finalizing a solution.
How can understanding the concepts of tension, overturning, and friction be applied to real world problem solving?
Understanding these concepts can be applied to a variety of real world scenarios, such as designing structures or machinery, determining the stability of objects on slopes or inclines, or even just everyday tasks like moving furniture. By understanding how these forces interact and affect stability, you can make more informed decisions and come up with effective solutions.
