Please help. Points of inflection and chain rule
stanton
Skethch the greaph of x^3/(x^3+1). Identify all extrema and points of inflection, asymptote equations, and easily found intercepts
If a/b=0, a must be 0.(thats how I got critical points from first derivative)
And chain rule: F'(x) = f '(g(x)) g '(x)
And so on.
What I have to do is to find points of inflection, asymptotes, and critical points. And I took the first derivative using Quotient rule and got 3x^2/(x^3+1)^2
I am going to take the second derivative of my original function to get ponts of inflection, but I am stuck.
As you can see, f'(x) = 3x^2/(x^3+1)^2
And I pondered a bit for I think I need to use chain rule because of that (x^3+1)^2 in the denominator. But how should I use it? what about the numerator?
I can't just use chain rule in the denominator, and use power rule in nominator on my own, right? I have a bad feeling about this.
This is what I will get if I apply power rule in nominator and apply chain rule in denominator:
6x/[2(x^3+1)(3x^2)] This is wrong, right? because I treated numerator and denominator by using different rules on each of them. Can you check this for me? What should I do in order to get the second derivative?
Or can I just ignore the denominator and just take Quotient rule again to get derivative?
Your second derivative doesn't look quite right.
Since you're having trouble getting the second derivative, try doing it in steps, starting from f'(x) = 3x2/(x3 + 1)2
Let g(x) = 3x2 and h(x) = (x3 + 1)2. Find g' and h' and then just plug everything into the right side of the quotient rule formula
\left(\frac{g}{h}\right)' = \frac{h'g - gh'}{h^2}
and simplify.
Now I get it. I was quite chaotic when I first saw this problem. Thank you for your advice!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
