Point Charge Electric Field Problem
Rettro
I've got a test coming up on this, and got quite a few of the questions on the related homework wrong. Attached is the problem, my solutions, and the book(correct) solution, please try to find what I'm doing wrong, this is driving me nuts.
Two charges exist along the Y axis at Y=0cm and Y=10cm, both at 3.0nC. What is the electric field at (5cm,10cm), 5cm right of the upper charge.
The book has a picture of this, my description may not be perfect. Simply, two 3.0nC charges 10cm apart one above the other, what is the electric field 5cm to the right of the upper charge.
Point Charge Field, E = [Kq/r^2] * Unit Vector
Pythagorean Theorem, A^2+B^2=C^2
E1, lower charge. E2, Upper charge.
E1U --> E1 Unit Vector
E1U --> tan^-1(0.05m/0.1m)
E1U --> 26.565 degrees
E1U --> sin(26.565 degrees) = 0.4472 i
E1U --> cos(26.565 degrees) = 0.8944 j
E1U = 0.4472 i + 0.8944 j
(Check, 0.4472^2 + 0.8944^2 = 0.99999. Unit Vector)
E1 = [Kq/r^2] * Unit Vector
E1 = [(9E9 Nm^2/C^2)(9E-9 C) / 0.0125 m^2] * (0.4472 i + 0.8944 j)
E1 = [(27 Nm^2/C) / (0.0125 m^2)] * (0.4472 i + 0.8944 j)
E1 = 2,160 N/C * (0.4472 i + 0.8944 j)
E1 = 965.952 N/C i + 1,931.904 N/C j
E2 = [Kq/r^2] * Unit Vector
E2 = [(9E9 Nm^2/C^2)(9E-9 C) / (0.05 m)^2] * i (Right(X) Vector)
E2 = [27 Nm^2/C / 0.0025 m^2] * i
E2 = 10,800 N/C i
E = E1 + E2
E = 965.952 N/C i + 1,931.904 N/C j + 10,800 N/C i
E = 11,765.952 N/C i + 1,931.904 N/C j
Emag = sqrt(11,765.952^2 + 1,931.904^2)
Emag = sqrt(142,169,879.5)
Emag = 11,923.5
Edir = tan-1(1,931.904 / 11,765.952) <-- Degrees over X axis
Edir = 9.324 degrees
E = 11,923.5 N/C <9.324 degrees above the X axis
However, the book solution (what the teacher wants) is:
1,180 N/C <5.5 degrees above the X axis
Your answer is right. However, your solution is unnecessarily complicated. It should only take a few steps:
E1_mag=kq/r1^2
E1_x=E1_mag*cos(theta)
E1_y=E1_mag*sin(theta)
E2_x=kq/r2^2
Ex=E1_x+E2_x
Ey=E1_y
So you think I should ignore what the book says? Would certainly make my life a heck of a lot easier.
As for the complication, we're doing the same maths only mine is in a lot more steps - I do that because of a touch of dyslexia, when I swap two numbers I shouldn't its easier to fix it later when every step is down on paper.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
