What is the Connection Between Polar Coordinates and Integrals?
  • Thread starter Thread starter Phymath
    Integral Polar
The discussion revolves around the connection between polar coordinates and integrals, specifically addressing two integral problems. The first problem involves demonstrating a relationship through a change of variable, suggesting the use of polar coordinates to simplify the integral. The second problem focuses on differentiating a function defined by an integral and expressing the result in elementary functions. Participants clarify the application of trigonometric substitutions and the relevance of polar coordinates, with some confusion about the proper substitutions. The conversation emphasizes the importance of understanding variable changes in integral calculus.
Phymath
two questions...
1) by a change of variable show the following...
\int^{\infty} _{-\infty} \frac{dt}{(a^2 + t^2)^{3/2}} = \frac{2}{a^2}\int^{\pi/2} _0 cos \ t \ dt
i'm thinking about changing this to polar cords and see where that take me anyone?
2) F(x) = \int^{cos \ x} _0 e^{xt^2} \ dt , \ G(x) = \int^{cos \ x} _0 t^2 e^{xt^2} \ dt, \ H(t) = G(x) - F'(x) express H(x) in elementry functions.
F&#039;(x) = \frac{\partial cos \ x}{\partial x} e^{xt^2} - 0 + \int \frac{\partial}{\partial x} e^{xt^2} \ dt \\<br /> = -sin \ x \ e^{xt^2} + \int t^2e^{xt^2} \ dt
<br /> H(x) = \int^{cos \ x} _0 t^2 e^{xt^2} \ dt + sin \ x \ e^{xt^2} - \int t^2e^{xt^2} \ dt <br /> <br /> = sin \ x \ e^{xt^2}
Did i do the dirv correctly? and how do I show that H(\pi/4) = \frac{e^{\pi/8}}{\sqrt{2}}
Phymath said:
two questions...
Hint : try \frac{t}{a} = \tan \theta
For the second,u should plug t\rightarrow \cos x and then it will be simple to find the final formula...
Daniel.
P.S.What polar coordinates...?It's not a double integral...
why would i plug t in for cos x? do u mean t for x so its cos t? I am confused why i would do that
i have to take the function at the upper limit don't I? yep yea i do, ok thanks all
