Automotive What type of suspension does the Porsche 911 have?
  • Thread starter Thread starter mehdi karami
    Suspension
The Porsche 911 features a torsion bar suspension system with telescopic dampers, classifying it as a passive suspension. This design does not utilize coil springs. For technical data such as dimensions, damper coefficients, and spring rates, contacting Porsche directly is recommended. The discussion emphasizes the importance of understanding the suspension type for analyzing forces. Overall, the 911's suspension is a key aspect of its performance characteristics.
mehdi karami
Hey guys .
Does anybody know about the type of car suspension in porsche 911 ?
I want to analyse the forces on its suspension , So i have to know that it's active ,semi active or passive suspension ?
Can I choose one of them arbitrarily?
"Proper" Porsche 911s have torsion bar suspension with telescopic dampers, this is a passive system.
Tank you veryyyyyy much,
So would u please tell me how can i get some technical data of its coil spring and damper , such as dimensions , damper coefficients, spring rate , moment of interia ,etc ?
Well, it doesn't have a coil spring. Like I said, it's a torsion bar arrangement.
You could try getting in touch with Porsche for that kind of technical information.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
