Possible title: Finding Initial Velocity and Distance of a Projectile
To find the initial velocity of a projectile given specific parameters, the formula dy = v1y t + 1/2 ay t² is used, with dy set at 4.961m and ay as -9.81 m/s². The time to reach this height can be calculated as t = √(2dy/ay), yielding t = 0.43s. The initial velocity in the y-direction (v1y) is assumed to be 0 m/s, leading to a correction in the distance formula. The correct equation for vertical displacement is d_y = V_{iy}t - 4.905t², which clarifies the calculation for dx. Understanding these equations is crucial for accurately determining the projectile's motion.
8320
You are to find the initial velocity of the projectile, then use this velocity to calculate dx when dy=4.961m
given
dx=0.92m
dy=0.42
ay=9.81
v1y=0
2. Homework Equations
To find the time, you use the formula dy=v1y t + 1/2ay t2
You would also use this formula to find the initial velocity
3. The Attempt at a Solution
For the time, it would be the square root of 2dy over ay
t= 0.43s for the second part, t= 1.01s
then you put t= 0.43 into the above equation for the velocity...
this is where I am running into trouble...
what is the velocity?
it is this velocity that you use to find dx.
the equation in my textbook is dx=v1x t
I know that the dx will also be in the general area of 0.80-90m
It seems you have some errors in your question.
I assume that v1y=0 is to mean that the initial velocity in the y direction (V_{iy}[/tex]) is 0 m/s.<br /> I also assume that by ay=9.81, you mean to say that the acceleration of gravity is assumed to be 9.81 m/s^2[/tex]. Since gravity is downward, then you should have a_y=-9.81 m/s^2[/tex]&amp;lt;br /&amp;gt; &amp;lt;br /&amp;gt; If that is true, then dy (the displacement in the y direction) can never be positive.Additionally, you have the formula for distance written incorrectly; it should be:&amp;lt;br /&amp;gt; d_y = V_{iy}t + \frac{1}{2}at^2 = V_{iy}t - 4.905t^2&amp;lt;br /&amp;gt; (note that there is no velocity value in the t^2[/tex] term.)
