Why is a Potential Divider Required in Sensor Circuits?
A potential divider is essential in sensor circuits to achieve the desired voltage across the sensor by adjusting the resistance of r2. This configuration enhances the sensor's sensitivity, as small changes in resistance result in larger variations in output voltage. The sensitivity can be determined by calculating the derivative of output voltage with respect to sensor resistance. Maximum sensitivity occurs when the resistances of r1 and r2 are equal. Understanding this relationship is crucial for optimizing sensor performance in various applications.
lincsimp
Why is a potential divider required in a sensor circuit?
V_out = r1/(r1+r2)*V_in
Firstly you can get the required voltage across the sensor by changing the resistance of r2 (if r1 is the sensor).
Apparently, though, using a potential divider also increases the sensitivity of the sensor. ie. a small change in resistance causes a larger change in output, but I don't see how this works. could someone explain?
Thanks
any ideas?
Your answer seems logical - i.e.to get the correct voltage drop across the sensor.
You can work out the sensitivity by calculating d v_out/dr1 where r1 is the sensor resistance, as a function of r1 and r2.
ah thanks! a bit of calc shows that you have maximum sensitivity when r1=r2...
