Potential Energy: Exploring Qs on Thermal & Drift Velocities
In summary, the potential at the negative terminal of a battery is always 0 volts, regardless of the load or current drawn. The battery's voltage may seem to drop if a lot of current is drawn or if the battery is going flat, but the negative terminal will still be at 0 volts. The temperature of electrons is often measured in electron volts (eV) and depends on both the thermal velocity and the drift velocity. A cold electron at room temperature can have a lot of energy if it is accelerated, and a slowly drifting electron with a high temperature also has a high "electron temperature".
Tinne
This is not a real existing homework problem but I do have two questions.
Q.1. In a circuit with a battery of 12 V, one always draws a scheme in which 0 V is written next to the negative terminal. Now, consider only a low resistance (and assume no short circuit will occur), is the potential at the negative terminal of the source near to 12 V (because of the low resistance) or is it always near to 0 V because the electrons lose/use their energy anyway, independing of the resistance they experience.
Q.2. The temperature of electrons is often written in electron volts (eV). The temperature, does it depend both on the thermal velocity and the drift velocity? So a cold electron (at room temp) can have a lot of energy if it is accelerated (or does the thermal energy increases as well then) and a slowly drifting electron with a high temperature also has a high "electron temperature"?
thermal velocity: sqrt(3kT/m)
drift velocity: sqrt(2qV/m)
with V the potential difference.
Hours of search to a simple explanation but nothing found so far.
The potential at the negative terminal of the battery is always exactly 0 volts (for the cases you are considering). It is defined as being 0 volts, and doesn't change with the load. If the load draws a lot of current, the battery voltage will seem to drop, in which case the positive terminal is no longer delivering +12 volts, it may fall to +11 volts, or even less. Same thing happens when the battery is going flat.
Related to Potential Energy: Exploring Qs on Thermal & Drift Velocities
1. What is potential energy?
Potential energy is the stored energy an object has due to its position or configuration.
2. How is potential energy related to thermal velocity?
Thermal velocity is a measure of the average kinetic energy of particles within a substance. This kinetic energy is directly related to the potential energy of the particles, as it is the energy they possess due to their position within the substance.
3. What determines the amount of potential energy in a substance?
The amount of potential energy in a substance is determined by the type and arrangement of particles within the substance. For example, a substance with closely packed particles, such as a solid, will have higher potential energy than a substance with more spread out particles, such as a gas.
4. How does potential energy affect drift velocity?
Drift velocity is the average velocity of charged particles in an electric field. Potential energy can affect drift velocity by changing the speed and direction of the particles as they move through the field. This is because potential energy is converted to kinetic energy as the particles accelerate in the field.
5. Can potential energy change into other forms of energy?
Yes, potential energy can be converted into other forms of energy, such as kinetic energy, thermal energy, or electrical energy. This conversion occurs when the object or substance undergoes a change in position, configuration, or state.
