How to Calculate V3 or Q3 in a Capacitance Network?
hectoryx
A capacitance matrix represents the charge coupling within a group of conductors — that is, the relationship between charges and voltages for the conductors. Given the three conductors shown in the following link, with the outside boundary taken as a reference,
http://i1021.photobucket.com/albums/af335/hectoryx/capacitancenetwork.jpg
the net charge on each object will be:
$\begin{array}{l}<br /> {Q_1} = {C_{10}}{V_1} + {C_{12}}({V_1} - {V_2}) + {C_{13}}({V_1} - {V_3}) \\ <br /> {Q_2} = {C_{20}}{V_2} + {C_{12}}({V_2} - {V_1}) + {C_{23}}({V_2} - {V_3}) \\ <br /> {Q_3} = {C_{30}}{V_3} + {C_{13}}({V_3} - {V_1}) + {C_{23}}({V_3} - {V_2}) \\ <br /> \end{array}$<br />
The problem is, if all of the capacitances are already known, and {V_1} - {V_2} = U is also known, but {V_1} and {V_2} is not known.
then how to calculate {V_3} or {Q_3}?
Thanks in advance.
Regards
Hector
I don't believe that it is possible. You have six unknowns, but only four equations. Do you know any other values besides just V1-V2? Two more independent values should do it.
Thanks for your reply.
However, in the equivalent circuit of the capacitor network, the voltage of conductor 3 to the reference ground can be caculated...so...
hectoryx said:
... in the equivalent circuit of the capacitor network, the voltage of conductor 3 to the reference ground can be caculated ...
Are you suggesting that this is possible if you only know V1-V2? I don't believe so. If you simply mean that, yes, there is this additional input information, then the solution is trivial: V3=V3, right? I must not be understanding your problem.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
